Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2007, 07:46 PM   #1
rimler
CF Senior Member
rimler's Avatar
Default Predator Tunes and dyno results for Z06
As I look through the tuner section, I really do not see much info or results from a predator tune. I had a 2005 GT and put a tune on it, and SOP there was a definite difference. I know that many like to go to tuners and have a custom tune done, but if you are running a stock Z06, a standard tune from a pre-programmed tuner such as a predator should do the trick right? Does anyone have dyno results from a predator tune
rimler is offline   Reply With Quote
Old 02-18-2007, 08:11 PM   #2
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
the best results from an out-of-box Predator tune is on an automatic trans C5 (mainly because it turns off Torque Management).
On 6 speeds, the OOB improvement isn't as great. But you could advance the timing by 4 percent, and lean out the AFR (but I would only do the latter using a wideband AFR setup).
Mike Mercury is offline   Reply With Quote
Old 02-18-2007, 09:00 PM   #3
rimler
CF Senior Member
rimler's Avatar
Thanks. Any Dyno results out there?
Old 02-20-2007, 09:54 AM   #4
JEEP/C5
CF Senior Member
JEEP/C5's Avatar
My new VETTE magazine took a new LS1 engine and they put in stiffer push rods, new ZEX performance plugs and a FAST-FLASH Power Program in and dynoed it at 11 HP and 12 TQ at the crank. I don’t know if a Predator would do much more HP and I don’t see push rods and plugs netting anything (maybe 1 HP IMO).
This was stage 1 of 4 stages and they were buying components that worked together in stages from Comp Cams. The next stages included valve springs, retainers, guide plates and studs with 1.75:1 rockers (18 HP, 16 TQ) then added a cam (56 HP, 36 TQ) and finished with new FAST intake with 90 mm TB and larger fuel rails for a grand total of 64 HP and 40 TQ at the crank. (These #’s are cumulative not for each mod individually).
Just thought this might help and I thought it was interesting to see how these components worked together. Perhaps with all the mods the computer programer helped much more than 10 ro 11 HP in the end.
JEEP/C5 is offline   Reply With Quote
Old 02-20-2007, 10:43 AM   #5
Mike L.
CF Senior Member
Quote:
The tunes in the Predator will provide solid gains, especially in low end torque and throttle response.
Remember though, you are starting with a truly powerful car, unlike the Mustang, so the gains will not be as great in SOTP.
I just looked through some dyno sheets and did not see any from a stock C5, I have Procharger dynos, H/C/I setups, and even an STS Vette, but no stock C5s. I will look around and ask our GM tuner when I see him.
PM me with an email address so if I find one I can send it to you.
Mike
Mike L. is offline   Reply With Quote
Old 02-21-2007, 12:02 AM   #6
mauitom
Junior Member
mauitom's Avatar
Quote:
Mike
How about posting it here?
__________________
2004 Z06 12.629@114.84 Torch Red
mauitom is offline   Reply With Quote
Old 02-22-2007, 05:07 PM   #7
rustyguns
CF Senior Member
rustyguns's Avatar
Send a message via Yahoo to rustyguns
Default Yeah !
Quote:
YEAH !!!!!!!!
rustyguns is offline   Reply With Quote
Old 02-22-2007, 05:08 PM   #8
rustyguns
CF Senior Member
rustyguns's Avatar
Default Ok
What does SOTP stand for?
darn acronyms!
Old 02-22-2007, 06:27 PM   #9
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
Seat Of The Pants! Other wise known as the ASSOMETER!
BC
Bill Curlee is offline   Reply With Quote
Old 02-22-2007, 07:53 PM   #10
DBLX
CF Senior Member
DBLX's Avatar
Send a message via MSN to DBLX
Default Pred?
If TQ management is turned off, what do you lose? Pro's? Cons? Is there different settings or just on or off?
TIA,
DBLX
DBLX is offline   Reply With Quote
Old 02-22-2007, 08:14 PM   #11
rustyguns
CF Senior Member
rustyguns's Avatar
SOTP HAHAHAHAHA I HAVE ONE OF THOSE
Old 02-22-2007, 08:14 PM   #12
rustyguns
CF Senior Member
rustyguns's Avatar
Quote:
TIA,
DBLX
TQ? WHATSA TQ ?
Old 02-22-2007, 08:55 PM   #13
DBLX
CF Senior Member
DBLX's Avatar
Default lol
torque.
Old 02-22-2007, 10:37 PM   #14
rustyguns
CF Senior Member
rustyguns's Avatar
Default woohoo!
torque.
oh man iwant some of that! TQ rules !!!!!!!!!
thanks!
Old 02-23-2007, 12:44 AM   #15
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most C5's have Torque Management. If I'm not mistaken,,the Z06's come stock with it OFF.
Its a computer program that LIMITS the Torque that your engine can provide to "protect the drive train" especially if you have an automatic. It only allows the throttle blades to open far enough to make the TQ limit. I don't know if it effects timing.
If you build a 500 HP engine with 475 ft/lbs OF TQ and you have Torque Management set at 300 ft/lbs,,,thats all the computer will allow it to apply to the drive train. Most tuners just turn it off if you have a manual trans or a ruggitized A4.
If you have a stock A4,,,,,it might shorten its life.
BC
Old 02-23-2007, 12:58 PM   #16
Mike L.
CF Senior Member
I have tried, always says it is too big. I'm no pro at resizing stuff, and frankly do not have the time to mess with it.
If anyone would like to post it or host it somewhere, PM me and I will send it to anyone who wants it.
Mike
Old 02-23-2007, 02:40 PM   #17
rustyguns
CF Senior Member
rustyguns's Avatar
Mike
ok send it to me ! pm you shortly
Old 02-25-2007, 09:23 PM   #18
rustyguns
CF Senior Member
rustyguns's Avatar
Default ? send me a copy?
hello? anyone out there?
Old 02-25-2007, 09:35 PM   #19
Mike L.
CF Senior Member
Quote:
Haven't forgotten about you. I looked through some dyno charts on Friday, but did not see any sheets showing the gains, just results after the tune.
I will discuss this with our GM tuner tomorrow and see if I can get a sheet to you.
Mike
Old 02-26-2007, 10:21 PM   #20
rustyguns
CF Senior Member
rustyguns's Avatar
Default !
THANKS!
Reload this Page Predator Tunes and dyno results for Z06
Tags
c5, c6, corvette, dyno, predator, results, tune, tunes, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Predator results boss4zo6 C5 Z06 Discussion 43 01-27-2004 01:35 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
