Want to know what is going on under the hood? Have you done mods but never had it tuned afterwards? Want to try to squeeze a few more out of it? Want to know where your LTFT's are and what your A/F ratio is?
We have tuned many cars both NA and FI using HPTuners Software. With Spring right around the corner we are offering a street tune special to help you get the most out of your late model GM car.
Cost $275 and includes:
Before and after scanning logs in Excel or .CSV formats
Check for Codes
Kill unwanted codes (Rear o2's?, No cats?)
WideBand o2 Sensor Air/Fuel Readings (post cat if you have cats)
Idle
Timing
Fuel Trims
Airflow
Injector Flow Rates
Power Enrichment (WOT)
Torque Management
Rev Limiter
CAGS Turned off (MN6)
Shift Points/Firmness Adjusted (A4's)
Fans
Tire Sizes/Speedo
If we make mods to your car down the road, incremental computer tunes will be offered at a discounted rate!
Give us a call Monday through Saturday from 8am-6pm if we can be of any help.
__________________
Specializing in Corvette and Muscle Car Performance & Tuning, Restoration, & Mechanical Repairs.
You want Specials! Call us!
Servicing the Mid-Hudson Valley and Surrounding Area.
Installer and Tuner for all popular SC, TT, N2O, Heads and Cam Packages, and more.
Want your Vette Overhauled, call us!
This has been a wonderful experience and the car is running much better. The drivability is much improved and the street performance is stronger. Exactly what I wanted.
I appreciate your time and your professionalism.
I am glad I've found your shop through this experience.
