Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-13-2007, 12:06 PM   #1
DIXZ
CF Senior Member
DIXZ's Avatar
Default Throttle Position Sensor
Just wondering if others have the same issue.
When scanning at idle or during deceleration I never see the throttle position go below 6%. This is on a manual transmission.
On the Grand Prix there is a throttle position relearn procedure, however it doesn't seem to work on the 'Vette.
Any Ideas?
DIXZ is offline   Reply With Quote
Old 02-13-2007, 12:22 PM   #2
see5
CF Senior Member
see5's Avatar
If it closed the engine would die.
__________________
2000, 6M, Kinesis rims, VBP springs, Bilsteins, Poly bushings, CCWs -315/335 Hoosiers, (SM2), Cross-bar, G-Force harness, Sparco EVO 2 seat, forged, stroked LS7 (441CI), Halltech, Blackwing, Shaner TB, PowrMAF 100, LS3 intake, ported LS3 heads, not too much cam, Fast 50# injectors, C6 oil pan, Accusump, RPS Twin CF clutch, Kooks 1 7/8" headers, 3" catless midpipes, Z06 TIs, hardened 3.90 rear, EFILive V2, LM-2 wb, always tuning.
see5 is offline   Reply With Quote
Old 02-13-2007, 06:12 PM   #3
tblu92
CF Senior Member
tblu92's Avatar
The Idle fuel cell is different than the deceleration fuel cell--Idle is cell 20 & deceleration is cell 21 .The two should not have anything in common --maybe only by coincidence.I have heard of an Idle relearn procedure but never of a throttle position relearn.You would have to check in the manual I guess. Also generally only cammed cars will have idle issues that force the IAC counts over 100.If you get the IAC counts over 100 then the idle will be adjusted with the throttle position
Not the right way they tell me to adjust idle--You want to get the TPS % as low as possible and the IAC counts under 100. I don't know if you have a cam or not--But if you are STOCK then the TPS should not be that high but closer to "0" at Idle---points to some other problem--Could be your LTFT's are way off (fuel trims) at idle or timing too low.
tblu92 is offline   Reply With Quote
Old 02-13-2007, 06:25 PM   #4
see5
CF Senior Member
see5's Avatar
I think he is just talking about Absolute throttle Position -(SAE. TP)
Old 02-13-2007, 11:44 PM   #5
DIXZ
CF Senior Member
DIXZ's Avatar
Thanks for the replys!
Car is stock except for a Blackhawk intake. I am trying to learn the LS6 after being in the V6 Supercharged arena.
I am used to a 0% TPS at idle with IAC in the area of 80.
I am here to learn and if I am off base please correct me!
Old 02-24-2007, 09:05 PM   #6
tblu92
CF Senior Member
tblu92's Avatar
The intake will throw your fuel trims way off--drive it around for about 100 miles and it will try to relearn some--If it doesn't re-learn back to 0 fueltrims and close to 0 % TPS at idle--you should adjust the "desired airflow table " b4307 by adding a % to it globally and that corrects the high TPS % at idle
Reload this Page Throttle Position Sensor
Tags
adjust, c5, corvette, counts, grand, gtp, iac, idle, low, ls, position, prix, relearn, sensor, throttle, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Throttle Position Sensor Adjustment ZZZZZR1 C4 ZR-1 Discussion 13 02-15-2002 09:02 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
