Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2007, 09:47 AM   #1
Billdog350
CF Senior Member
Billdog350's Avatar
Default Jagged MAF Log/graph in cold weather?
Guys, I'm running a Vararam and stock MAF in my intake setup but my MAF frequency/gms per sec look pretty jagged. Obviously this would throw off my tune and hurt fuel economy. I have a spare maf but its a PITA to swap it since the current one is stuck on the vararam. Before I go swapping things, has anyone else seen this behavior in cold weather and is it normal? I'm guessing a variation of ~30 gms/sec at WOT (55gms/sec to 85gms/sec with no throttle or RPM changes) is not good.
Billdog350 is offline   Reply With Quote
Old 02-13-2007, 12:02 AM   #2
tblu92
CF Senior Member
tblu92's Avatar
My only guess is that you are injesting some water or moisture into the air tract--(could be even just fog) and the Vararam is prone to that because of its design as it is any true ram air system.Any moisture would make the fine wires in the MAF give you some spikes or false readings---Lately there has been a lot of talk about filter oil causing the same issues with open air boxes making the MAF's go haywire.Some manufacturers have gone to oiless filter elements because of this.
tblu92 is offline   Reply With Quote
Old 02-13-2007, 10:29 AM   #3
Billdog350
CF Senior Member
Billdog350's Avatar
Thx for the suggestion, I'll try cleaning the MAF again in case there is any filter oil on there. There isn't much chance of moisture in the air here in CT, its been like 20 deg during the day and single digits at night!
Old 02-13-2007, 02:55 PM   #4
Billf6531
CF Senior Member
Billf6531's Avatar
If you haven't corrected your MAF table for the Vararam, that's your problem. The stock air filter channels the intake air through/across the centre of the screened MAF, and the table is designed to read it accurately. If you want a good table to start with, use the values from a 6.0 litre truck MAF, and tune from there. If you've already done this, then I too would suspect oil on the MAF wires.
__________________
Best regards,
Bill
Calgary, Alberta, Canada
2003 Quicksilver roadster , 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe & air lid, Euro red/amber tails, Vette Net, and HP Tuners s/w - available for free to anyone in Calgary
Billf6531 is offline   Reply With Quote
Old 02-14-2007, 12:38 PM   #5
phils C5 vette
CF Senior Member
phils C5 vette's Avatar
Quote:
with my vararam, Ive driven in 3 1/2 hours in the pouring rain in the highway and highway speed, and the grey filter, and I didnt get water in anything !
Like any other intake system, if you submerge it in water, it will suck some up. Not in normal driving conditions.
Ive had the vararam on for 4 years and my throttle body is hardly dirty.
__________________
www.TampaTuning.com
813-727-8720
Tuned by Tampa Tuning
[SIZE="5"]451.1 RWHP@ 5900 432.8 RWTQ@ 4900
phils C5 vette is offline   Reply With Quote
Reload this Page Jagged MAF Log/graph in cold weather?
Tags
graph, maf
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
