Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-05-2006, 02:56 PM   #1
Sabre 6
Junior Member
Default Check Engine Light PC Code
I have a 1998 Corvette with 22K miles. I recently installed Mid-America's Complete Ram Air Intake System with the high flow mass air sensor. Soon afterwards I began to get an intermittant check engine light. I ran the PC Codes and got P0171/2, "fuel trim system lean." The light will come on for a couple of days then go off for a couple of days. Is the computer confused by the increased volume of air? Can someone help me understand what's going on? Any help would be very much appreciated.
Sabre 6 is offline   Reply With Quote
Old 07-05-2006, 05:56 PM   #2
muncie21
CF Senior Member
muncie21's Avatar
A lean code means your car is running leaner than the PCM can compensate for, it could also mean that you have an air leak somewhere. If I were a betting man, I'd be betting on the latter. Double-check all of your airbridge connections and make sure you don't have an air leak.
muncie21 is offline   Reply With Quote
Reload this Page Check Engine Light PC Code
Tags
america, cel, install, intake, mid
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Are you still legal (in Texas) without the pre-cats? Tiger Shark C5 Tech 38 09-28-2010 01:46 PM
85 tuning Insane1 C4 Scan & Tune 50 08-05-2005 09:14 AM
Oxygen sensors and code issues ZR1991 C4 ZR-1 Discussion 9 06-03-2004 04:40 PM
Check Engine light after LS1 edit. OK to disconnect battery to reset? Nat04Z06 C5 Tech 10 08-03-2002 03:46 PM
Heads & Cam vs. new smog laws effictive 1/1/02 vetterdstr C5 Tech 40 01-04-2002 12:15 PM
Why not 150 octane Alcohol??? BrianCunningham Engine Mods 32 10-27-2001 12:34 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
