Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-02-2006, 03:16 AM   #1
chargedc5
CF Senior Member
chargedc5's Avatar
westin roberts Westin Roberts
Default PLEEEAAASE HELP with codes
Installed headers and Supercharger with mail order tune on A4. The car is running super rich. Its chugs and idles rough unless im in the gas.
Its running codes PO132C, PO300H which is O2s. Tried putting new o2 in both sides and nothing same codes. Put scanner on and it read around 960mv on bank 1 sensor one. So right now I pulled fuse to run open loop. Can the o2s be crossed or what, NEED HELP.
Also running TCS1286HC and HVAC BO333HC are they because of the o2s.
Do you think it is more in the tune or something I did?????!!!!!????!!
chargedc5 is offline   Reply With Quote
Old 07-02-2006, 07:20 PM   #2
dpd
CF Senior Member
960mv means you are rich[132=o2 voltage high]300 is random misfires,probably because you are rich.pulling the fuse will make bank 2 rich[o2 will run cold],bank 1 fuel trims should be on the minus[-]side with running that fat.pull the plugs on 1.if they are all black,you have too much fuel.if the plugs don't look that bad,either you have a wiring problem or a bad o2 [most likely if you have a lot of miles].swap front o2's,if the fault goes to bank 2 ,your issue is a dead o2.
dpd is offline   Reply With Quote
Old 07-04-2006, 01:09 AM   #3
chargedc5
CF Senior Member
chargedc5's Avatar
I tried a new 02, I think I have a wire problem from installation, its just finding put were it is. I just didnt know if it could be the computer. Thanks though.
Reload this Page PLEEEAAASE HELP with codes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
