Quote:
Originally Posted by audioslave38501
i have a 99 c5 and am having the colum lock issue, it has been at the dealer for 4 days and they are clueless, the recall was done a few years ago and the "k" harness relay is getting very hot when the key is on and the fuel is cut off at 2 mph, does anyone know where the main relay is located? i have heard there is one above the bcm on the passenger side? if so, which one is it? i have tried a clb and it also does not work, i get the pull key 10 sec msg, i got rid of a nice G35 coupe for the pile of junk, no wounder GM is in trouble, i will never buy another one!
Don't be hating on the corvette for some rice burner, just cause you have one problem.
I had the same problem a last year. It cost about $500 - $600 to get it fixed. You probably have a column lock motor failure, and I quote from the GM could help a soul customer service center, "IT IS NOT COVERED UNDER THE RECALL, since it is not a part listed on the recall"
I have been fighting them for 1 and 1/2 years now. I am looking into this class action that has been discussed on this forum. Let you know what comes of it. Doubtful.
Anyways. You have to take apart the column and remove the column lock plate.
Did you get your recall letter in the mail, if this happens take it in. Well, now is your chance. DO NOT LET THEM REPLACE ANYTHING, just have the cloumn lock plate removed and reprogram the PCM, so it doesn't try to activate it.
Hopefully, you didn't have any accidents or damage to the car. Search the web for the new 04006C recall issued this FEB 2006. Take that to the dealer.
Hope this helps.
