Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-27-2006, 05:03 AM   #1
SpinMonster
SpinMonster's Avatar
Send a message via AIM to SpinMonster
Default Injector Tuning
Anyone have any tips on tuning for bigger injectors? I want to go from 32.5's to 42's and was looking for info on injector flow rate and/or pulse. What gets changed?...both?
SpinMonster is offline   Reply With Quote
Old 06-27-2006, 10:57 AM   #2
John@SDPC
Premium Supporting Vendor
John@SDPC's Avatar
What software are you using? You will have to change the flow rate, and to determine the factor for changing that table use this formula:
New Injector Flow = Sqrt(New Fuel Pressure / Old Fuel Pressure) X Injector flow rating at old fuel pressure
Then factor = New Injector Flow Rate / Old Inject Flow Rate
If the numbers you have below are both the ratings of fuel flow at 58 psi (our normal fuel pressure), then you will have to increase the flow table by ~30% (42/32.5)
John@SDPC is offline   Reply With Quote
Old 06-27-2006, 01:22 PM   #3
muncie21
CF Senior Member
muncie21's Avatar
Do a search on LS1Tech for injector flow spreadsheet. RHS over there has a well refined spreadsheet that calculates the injector flows. The spreadsheet is kinda setup for HP Tuners, but the flow numbers are the same regardless of the tuning package.
muncie21 is offline   Reply With Quote
Old 06-27-2006, 02:30 PM   #4
John@SDPC
John@SDPC's Avatar
You can find the injector flow sheet here. However, be careful when entering data. Some systems may use g/s, lbs/hr for the flow (although if multiplying a percentage it doesn't matter what the base units are), or the axis might be in manifold vacuum or manifold pressure. Just an FYI.
Reload this Page Injector Tuning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Forum ECM-PCM Tuning Section FAQ Marcho Polo C4 Scan & Tune 141 05-18-2011 11:42 AM
Big injector, high HP stock computer dyno results Alvin C4 Tech/Performance 55 06-26-2005 10:50 AM
75 lb injector tuning ? Earl H C5 Scan & Tune 9 10-25-2004 12:17 AM
Halltech Stinger Questions RoHo C5 Z06 Discussion 36 09-25-2004 06:57 PM
LS1 EDIT Tuning Special 21STCENTURYMUSCLECAR C5 Tech 27 01-19-2003 03:00 PM
LS1_Edit Tuning Strategy SNW Vette C5 Scan & Tune 26 09-07-2002 02:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
