Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-26-2006, 04:01 PM   #1
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
Default C.E.L. code P0134 which o2 sensor do i replace?
Hello,
I have the following error code:
P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
which o2 sensor is that? (we have four don't we?)
thanks in advance.
scott
scott_fx is offline   Reply With Quote
Old 06-26-2006, 08:13 PM   #2
bshell
CF Senior Member
bshell's Avatar
Bank 1 = driver's side, Sensor 1 = pre-cat.
bshell is offline   Reply With Quote
Old 06-26-2006, 08:15 PM   #3
scott_fx
CF Senior Member
scott_fx's Avatar
thank you very much.
Old 06-27-2006, 12:27 AM   #4
Mr. Lucky
CF Senior Member
St. Jude Donor '06
Mr. Lucky's Avatar
Quote:
but this could also be caused by an exhaust leak before (or near) the catalytic converter - check the easy stuff first.
__________________
—Bob
Looking for a place to host your Corvette website?
Contact me for special Corvette Forum member discount.
http://www.TheWholeInternet.net
Mr. Lucky is offline   Reply With Quote
Old 06-27-2006, 11:11 AM   #5
John@SDPC
Premium Supporting Vendor
John@SDPC's Avatar
Check easy things first. Here are some detailed diagnostic steps for that DTC.
John@SDPC is offline   Reply With Quote
Old 07-18-2006, 04:16 PM   #6
patton
CF Senior Member
St. Jude Donor '09
patton's Avatar
A.I.R. pump not working can pop that code once and awhile . get a scan tool that can watch all 4 sensors at once . if you have alot of miles i would change all 4 . $ it hurts but only if that one is bad
patton is offline   Reply With Quote
Reload this Page C.E.L. code P0134 which o2 sensor do i replace?
Tags
bank, c5, change, code, corvette, cost, error, instructions, o2, oxygen, p0134, pacifica, po134, replace, replacing, sensor, sensors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
