Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-17-2006, 11:27 PM   #1
mperl93
CF Senior Member
mperl93's Avatar
Default Predator performance tune
I just got a predator and have an 04 A4 2.73 gears. I loaded the performance tune. It first saved my factory tune (as expected) and then I loaded the factory default performance tune. After this was done I took a look at the options to modify the performance tune. When looking at the Axle Ratio it was set at 3.42. Does that mean that it set my car up for 3.42 and I need to change it to 2.73? or is it fine the way it is?
I have a blackwing and Z06 exhaust so if there are any other changes you have found to work well let me know. I am going to put in 3.42 gears next month. With the 3.42 gears is it best to change the axle ratio to 3.42 and also set the shift mph tables?
thanks,
Mike
mperl93 is offline   Reply With Quote
Old 06-18-2006, 12:40 AM   #2
mperl93
CF Senior Member
mperl93's Avatar
I also want to know if when you modify the performance tune from a predator do you have to update all changable fields? For example if I adjust the shift pressure and shift speed do I need to make sure all the other feilds are default to what I expect them to be? (as stated above by default my predator shows the axle ratio as 3.42 and I have 2.73, so I don't want it to think I have 3.42)
Old 06-18-2006, 03:43 PM   #3
yaonttwo
CF Senior Member
yaonttwo's Avatar
Mine was the exact same way. However, the performance tune ran fine. When I changed to 3.42 I then had to adjust the rear end ratio.
The shift mph mentioned in the booklet (3.42 gears) also worked fine.
Good luck.
yaonttwo is offline   Reply With Quote
Old 06-18-2006, 03:54 PM   #4
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
leave it alone. For the Predzator, that setting is for F-Bodies (where a speedo adjustment is required). This is not needed on the C5, so just let the Predator "3.42" stay where it defaults to.
Mike Mercury is online now   Reply With Quote
Old 06-22-2006, 10:09 PM   #5
z edge
CF Senior Member
z edge's Avatar
I got my predator today, didnt have too much time to play around with it so i just loaded the performance tune before dinner. I just came back from a 20-30 minute drive now that its cooled off a bit outside and i noticed that while on the highway it seemed to have a nice pull. To test this i kept getting back on and off the highway several times to wot the nice long entrance ramps. It felt pretty good so im looking forward to modifying parameters ( some, not all ) when i learn more about it.
z edge is offline   Reply With Quote
Old 06-28-2006, 07:16 PM   #6
myblackC5
CF Senior Member
myblackC5's Avatar
Send a message via ICQ to myblackC5 Send a message via AIM to myblackC5
Default handheld tuners
Quote:
i installed my vinci/crane tune, there was a huge difference. i think taking off TM is the big part of it.
myblackC5 is offline   Reply With Quote
Old 06-28-2006, 10:47 PM   #7
Mike Mercury
CF Senior Member
Quote:
ding... ding... ding; we have a winner !
Old 06-29-2006, 12:30 AM   #8
hex
CF Senior Member
hex's Avatar
Just beware. Those and some other tuners overadvance the timing, and they feel great for the first few days, until they learn knock retard, and then they will start to slow back down, as they learn the low octane bias. Most do not notice this by seat of the pants, and attribute it to getting used to it. I could prove this to you on the dyno, if you'd like. You also, if you are not doing it now, should run GOOD 93 octane, which, the closest place to me, is 63rd and Western. You run 91, and you will see what I just described, either way.
jp
hex is offline   Reply With Quote
Old 06-29-2006, 01:54 AM   #9
purrvert
CF Senior Member
purrvert's Avatar
Quote:
jp
That's been my personal experience, loads of knock, misfire codes disabled, etc. Tuned it myself with much better results. I have to admit the car was quick at first but never could maintain idle and dropped the speed after a few WOt runs.
purrvert is offline   Reply With Quote
Old 06-29-2006, 04:44 PM   #10
GA Country Boy
CF Senior Member
GA Country Boy's Avatar
Send a message via AIM to GA Country Boy
thanks,
Mike
If you're ever going to see any performance gains you need to get rid of those 2:73's and get something like 3:42's (like the 6 speeds) or even lower like 3:73's unlee you're only looking for top end and don't care how long it takes to get there.
__________________
Michael the GA Country Boy
waving from '02 C5 LSX, Z51, F1R, 60lb injectors, RPM level 5-4L60E, 3:73, Yank 3800tc, QA1-12ways,
American Racing long tube headers, high flow cats, Wilwood brakes= 805 rwhp, 719 rwtq.(DynoJet 248-C)
10.89@127.57 through mufflers on street tires with former set up (603 rwhp), Race Weight with driver 3,640 lbs
GA Country Boy is offline   Reply With Quote
Old 06-30-2006, 09:17 PM   #11
z edge
CF Senior Member
z edge's Avatar
jp
thanks for the advice, yeah i do fill up w/ 93 at that station you are talking about. The car has ran fine even in this heat but tonight while driving down the expressway the active handling system started messing up and now it says i need to take it in for service. Im not sure should i just put the stock program and take the car in for service or what? Maybe going back to stock will fix whatever problem?
Old 07-17-2006, 04:16 PM   #12
Vette_Fan
CF Senior Member
Vette_Fan's Avatar
This is why I scared of Hand helds. I have not done any Dyno tuning either... but hope "they" dont mess it up..
Vette_Fan is offline   Reply With Quote
Reload this Page Predator performance tune
Tags
91, cranevinci, dyno, modifying, octane, performance, philadelphia, predator, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Has anyone "modified" the Predator performance tune? LRD VDR C5 Scan & Tune 10 03-15-2005 10:27 AM
pinging w blackwing pdykinga C5 Tech 21 01-26-2005 10:34 PM
Predator performance tune works w/91 octane??? Vette 4 Fun C5 Scan & Tune 10 01-06-2005 02:23 PM
Predator performance tune installed Mike04 C5 Scan & Tune 35 10-13-2004 07:35 PM
How does the Diablo "Performance Tune" compare to stock? C5 Scan & Tune 11 02-02-2004 08:07 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
