Is there such a product out there called "tuning for dummies"?
Seriously, is there any point in my looking into purchasing some tuning software, in order to make "routine" adjustments to my custom tuned PCM (H/C, hi stall TC, etc) on an '04 A4 coupe?
For example, shift points, corrections for fan speeds, and for rear-end gear changes, idle rpms, and for minor changes in timing to allow for driving in areas (like out West) where only 91 oct fuel is found and pinging/preignition is a common occurance in the deserts at 100+ degrees going up steep grades.
I am not inclined to be nickle and dimed to death by having to go to a professional tuner every time I want to have some minor adjustment made to the program.....besides there not being a reputable tuner within hundreds of miles of my location.
It's obvious (from what I've read and been told) that hand-held tuners are completely out of the question. So, is there a reasonable alternative available for a "dummie" like myself? If so, what are some of the recommendations....cost, ease of use, etc?
FWIW, I intend on keeping this vette for many many years to come, and not sell it off anytime soon.
Thanks for the links. Tell me though, if you know, would I be able to make the sort of adjustments I wish to make with this software, even though the PCM already has a custom tune in it from LS1 edit, without messing up that tune?
LS1 Edit is about $500 so it HP tuners
if you plan on keeping the car, either of those might be considered a good investment
when i plan on buying tuner software, i will order HP Tuners http://www.hptuners.com/order.php
There is a good book available called "Building & Tuning High-Performance Electronic Fuel Injection" by Ben Strader ISBN # 1-884089-79-8. It covers all kinds of after market EFI systems and also explains tuning pretty thoroughly. It sells for I believe $18.95 and is available from the publisher: www.cartechbooks.com
Amazon may have used ones available cheaper, but if you want to learn about tuning it's money well spent.
__________________
Michael the GA Country Boy
waving from '02 C5 LSX, Z51, F1R, 60lb injectors, RPM level 5-4L60E, 3:73, Yank 3800tc, QA1-12ways,
American Racing long tube headers, high flow cats, Wilwood brakes= 805 rwhp, 719 rwtq.(DynoJet 248-C)
10.89@127.57 through mufflers on street tires with former set up (603 rwhp), Race Weight with driver 3,640 lbs
