Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-09-2006, 07:52 PM   #1
rsxmanjoe
CF Senior Member
rsxmanjoe's Avatar
Default c5 z06 tranmission problem
The other day I was doing some spirited runs on the highway when my tranny got stuck in 6th....I pumped the clutch a few times and it came out...ever since then the tranny has been acting up....whenever i get into 3rd gear at a higher rpm it grinds badly, but at a lower rpm its fine....
does this sound like the snychros are ****ed up, or something else??? my buddy thought the clutch might need to be bled. Any help would be appreciated.
rsxmanjoe is offline   Reply With Quote
Old 06-12-2006, 11:31 AM   #2
SteveDotenMotorsports
Supporting Vendor
Cruise-In VII Veteran
SteveDotenMotorsports's Avatar
sounds like it may be a shift fork problem, swap the fluid in the clutch m/c
your best bet would be to call Rodney or Todd www.rpmtransmissions.com
SteveDotenMotorsports is offline   Reply With Quote
Old 06-12-2006, 05:00 PM   #3
rsxmanjoe
CF Senior Member
rsxmanjoe's Avatar
i was gonna bleed my master first....is there a write up anywhere on how to do this?
Old 06-17-2006, 11:18 AM   #4
ajg1915
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
ajg1915's Avatar
Since you probably don't have a remote bleeder, it is going to take two of you.
The bleeder is on the top left side of the torque tube where it meets the bellhousing. Think it's a 11mm.
Also you can use a turkey baster and suck up the fluid in the reservoir and replace with some fresh fluid.
If that does not fix it for you then drop the inspection cover and check to see if your clutch if fully releasing (air gap).
ajg1915 is offline   Reply With Quote
Reload this Page c5 z06 tranmission problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ARE/GWP 427 Z06 WITH ATI MAKES 720rwhp/710rwtrq !! Nick Agostino C5 Forced Induction/Nitrous 49 04-25-2002 01:57 AM
Z06 needs tranmission cooler for high speed sustained running Dove Autocrossing & Roadracing 17 10-05-2001 03:36 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
