Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-09-2006, 09:52 AM   #1
Billdog350
CF Senior Member
Billdog350's Avatar
Default VE LTFT tuning after Longtubes
Guys, I've been tuning the VE tables (In SD mode with MAF disabled) by datalogging the LTFT pids as well as MAF and RPM. I have reduced my LTFT from 10-15+ down to 5 so far....aiming for 0 or -3 when I'm done.
My question is: has anyone else done this and have they had to SIGNIFICANTLY alter their VE table (adding more than 10 to the existing values) to get things in line? I'm wondering why the logging is taking a while to respond. I drive it for 20-30 miles after each tune so it should be adjusting to the new trims. Also, I have been copying the main table to the backup table just in case that is affecting it. I've already added about 10-15 to all of the cells and I would have expected to be in the - range by now...
Billdog350 is offline   Reply With Quote
Old 06-09-2006, 04:23 PM   #2
Billdog350
CF Senior Member
Billdog350's Avatar
Found the answer from a fellow tuner.
You're supposed to be logging your STFT (Short term fuel trims) and making changes by PERCENTAGE...not numbers.
EG if your STFT's are high by 10 across the board, increase your table by 10% and you'll be much closer!
The car is now tuned to +-2% for the whole table which is better than I thought I'd be able to get....now time for MAF and PE tuning! Once my LC-1 comes in I'll be good to go!
Old 06-10-2006, 04:47 PM   #3
Darkness
CF Senior Member
Darkness's Avatar
What software do you have? I have EFILive and an LC-1 and need to get my LTFT's closer to 0 as well but I'm still too much of a newb to do it! lol My wot is good though, just the part throttle cruise.
__________________
Driver
Corvette FRC 408ci - 520rwhp
Callies Crank Eagle Rods Diamond Pistons Absolute Speed Heads 244 248 cam LG Headers FAST 90 TPIS 90 ATI UD 11.6cr RPM Trans DTE brace Spec 3+ Momo 4" cowl hood etc
Darkness is offline   Reply With Quote
Old 06-16-2006, 01:25 PM   #4
Billdog350
CF Senior Member
Billdog350's Avatar
tune your STFT's first. Log the STFT's vs MAP vs RPM.....look for large negatives or positives. Here is a great document on tuning basics.
http://www.wnyym.com/newbie/tuning_new.htm
http://www.ls1tech.com/forums/showthread.php?t=287094
Reload this Page VE LTFT tuning after Longtubes
Tags
diablo, ltft, tuning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
