Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-07-2006, 08:53 PM   #1
402Sam
CF Senior Member
Default Can a tune mess with the TCS
I am all ears....All my grounds are good, the car ran great before the short block swap and the only thing different is the tune now...
__________________
402 LS2
10.96@ 125mph 1.58 60' N/A
10.42@ 133mph, car shut off 20' before finish..
257/266 643/622 110 lsa cam
stg 3 livernios heads ported and polished.
Ported 90/90 intake ported
200 shot.
680rwhp..
Idle video
http://videos.streetfire.net/video/5...0e016f503c.htm
SOLD........
08 season:
93 touring FD RX-7
Heads/cam spray
9's or bust
www.ipsmotorsports.net
402Sam is offline   Reply With Quote
Old 06-07-2006, 09:52 PM   #2
SteveDotenMotorsports
Supporting Vendor
Cruise-In VII Veteran
SteveDotenMotorsports's Avatar
your 4 abs/speed sensors(also wheel bearings), feed into the transmission harness and which routes from the rear of the car of behind the motor, splits to the 2 front sensors and ends up next to the battery; the ground is at on the driver's side of the block for this harness, there is another on the frame rail near the driver's side rear
in the pic look below the aft most head bolt, it looks like the ground(loose) is touching the header
before you ck for the grounds, what CODES do you have?
SteveDotenMotorsports is offline   Reply With Quote
Old 06-08-2006, 08:34 PM   #3
402Sam
CF Senior Member
I keep getting the c1278. I see the ground you are talking about on the driver side of the block. If that ground is by chance touching the headers would that cause it not to work correctly. The problem I am having is the car ran fine before a short block swap, now I get this. At anything less then 10% throttle the car runs fines, anything over it goes into reduced engine power mode and service traction control and abs. But a WOT the car still will run great and pull nicely and not throw that code. It seems like anything from 10%-75% throws this code and causes the car to go into reduced engine power mode.
Reload this Page Can a tune mess with the TCS
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
