Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-05-2006, 04:32 PM   #1
Jserman
CF Senior Member
Jserman's Avatar
Send a message via AIM to Jserman
Default Low octane table
I am using Hptuner
I am running meth injection on my S/C car.....This map is in the high octane table
I put my map before the meth in the low octane table just incase the meth failed it would go back to low octane mode and the car would be fine..
it seems the car is stuck in low octane mode because my methe failed is there a way to get it out of it... or reset it or check it out anything..
help apprecaited
Jserman is offline   Reply With Quote
Old 06-05-2006, 07:36 PM   #2
muncie21
CF Senior Member
muncie21's Avatar
Map? Are you referring to the timing table? If you are stuck in the low octane table, just copy the values from low to high. The PCM starts to blend low octane with high when it sees knock. The more knock, the more it blends until you are running completely in the low table.
If you don't want to copy the high table to the low, then do some driving until the knock learn resets itself.
muncie21 is offline   Reply With Quote
Reload this Page Low octane table
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
"Stuck" in Low Octane Table? (also on Scan and Tune) MrLeadFoot C5 General 10 10-18-2004 09:31 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
