Does anybody know what features or options can be enabled or disabled with a Tech II tool? Or is there some other tool that can do this? Like I've heard that you can disable the F45 shock system. I'm also wondering if there is a Active Handling option that can be enabled? My '98 has a front mounted EBTCM but did not come with Active Handling which was an option on my late '98 C5. I read through the operators manual for "Ease" PC based Tech II software but did not see anything that might do any of these things.
John
John
John,
To my knowledge only the TECH II can turn off F45.
This is not an all-inclusive list, but will give you an idea of what can be addressed via Tech-II.
HTH!
__________________ —Bob
Looking for a place to host your Corvette website? Contact me for special Corvette Forum member discount. http://www.TheWholeInternet.net
Dumb question but does anyone know if a TechII can handle rear gear changes on a 97A4. I have HPTuners which does it for all 98-04's with the package I have. Does not support all 97's though.
You would obviously need the tc/ah switch wiring, plus all the sensors noted in the article. OTOH, the RPO code shown is the correct option for 1998 model year. It might be worth a try, unless someone can chime in with the definitive answer.
-Bob
Bob, I'm betting that since this was a production car with front-mounted EBTCM with AH offered as an option, then the only thing I would need to do is change the switch harness on the console and enable it. I doubt they had time to cost reduce by removing sensors and such. I bet all the sensors are there. I will start looking into this just to see what's there. I wish if someone else has already looked into this that they could offer some insight on this option.
John
