Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-24-2005, 01:46 PM   #1
2kvert
CF Senior Member
2kvert's Avatar
Default Codes:P0443,P0449,P0740,P0753,P1860....H ELP!
I've got problems. I need help on where to start. I'm just about to pull my hair out with these codes. I've had the motor out. Is it possible I pinched wires on the tranmission harness which is resulting in the tranny codes? Any help will be greatly appreciated.
2kvert is offline   Reply With Quote
Old 11-24-2005, 04:09 PM   #2
78Vette-SA
CF Senior Member
78Vette-SA's Avatar
I think we discussed some of these before but here it is again.
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0449 EVAP Canister Vent Solenoid Valve Control Circuit
P0740 Torque Converter Clutch Circuit
P0753 Shift Solenoid A Electrical
P1860 Torque Converter Clutch PWM Solenoid Circuit
The EVAP Cannister and connections are under the driver side fuel rail cover and tucked in under the fuel rail itself. There are vent connections to it as well as an electrical connection. There are various tests for it but main thing is to make sure it is connected.
For the TCC check the connector on the passenger side of the transmission (at the rear of the transmission) is seated all the way in. Beyond that, there are of course a series of tests to go through to test the TCC PWM. If it's more than a connection and you don't have a service manual or ability or friend to help fix, you may need to take it to someone knowledable to fix or replace. The solenoid itself is inside the transmission.
__________________
Email: Joe Santacroce
98 Black A4 Coupe Heads/Cam/N2O - 81 FrankenSport LS6SC/6spd/SRIII
78Vette-SA is offline   Reply With Quote
Old 11-25-2005, 12:39 PM   #3
TXNC5
CF Senior Member
TXNC5's Avatar
FYI, assuming you have 2000 Vette you can find almost every Pxxxx for the 2000 vette here. If you have a different year model, just go back to the main page and find your year model.
TXNC5 is offline   Reply With Quote
Reload this Page Codes:P0443,P0449,P0740,P0753,P1860....H ELP!
Tags
0443, 1996, 2000, circuit, code, control, corvette, emissions, evaprotive, p0443, p0449, p0740, p1860, replacement, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
