Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-24-2005, 12:22 AM   #1
slicksilver11
CF Senior Member
slicksilver11's Avatar
Default hypertech controller????
what exactly does this do? Adjusts tune? Does it really help?
Did a search, but can't find any info on it.
Any help would be appreciated.
slicksilver11 is offline   Reply With Quote
Old 11-24-2005, 04:26 AM   #2
LV Vette
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
LV Vette's Avatar
Send a message via AIM to LV Vette
Default Don't use it!!!
I tried one. Made the car run poorly and slower. POS, try the Predator tuner. Works good. Best of the handheld tuners.
Clayton
LV Vette is offline   Reply With Quote
Old 11-24-2005, 02:49 PM   #3
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Quote:
Clayton
there are better tuners out there other than the Predator, but IMO the Predator is the best "handheld" unit available.
The better more-capable non handheld varieties require a laptop computer.
Mike Mercury is offline   Reply With Quote
Old 01-02-2006, 02:39 AM   #4
shurite44
CF Senior Member
shurite44's Avatar
Send a message via Yahoo to shurite44
Performance tune
adjust shift points using mph
adjust shift firmness in increments of 25%
Adjust tire sizes for speedo, also had a setting for your speed rating on the tire
Does a few other things I can not remember them all anymore. I gained close to 2 tenths in the qtr mile ET. It will not scale for gear changes no matter what the directions say. Although I think it may work for a 2.73-3.15 swap. I liked it but next time around I would buy the predator.
shurite44 is offline   Reply With Quote
Old 01-02-2006, 10:04 AM   #5
502ci
CF Senior Member
502ci's Avatar
Quote:
Originally Posted by shurite44
Performance tune
It says the camaro setting can be adjusted to a 4.10 gear but for some reason the corvette can`t be adjusted. But you can beat that by calculating a different tire diameter in to get the speedometer back on track if you go to a 3.73 or 4.10 on the vette.
502ci is offline   Reply With Quote
Old 01-02-2006, 10:46 AM   #6
shurite44
CF Senior Member
shurite44's Avatar
Quote:
No you can not use the hypertech for a 3.73 or a 4.10. According to Hypertech the only gear scaling it will do in the C5 is for stock ratio's. So in effect the only time it would work is for a 2.73-3.15. A 3.42 in an auto can not be scaled correctly because it is not a stock rear for the auto, and the M6 only comes with one rear end ratio the 3.42. The gear change will not affect the speedo, but you do need to reprogram or scale for the new rear end ratio or it will throw codes.
I called hypertech and I believe Mike Mercury called them also. Tim (mike mercury) correct me if I am wrong here, you know more about it than I do.
Old 01-02-2006, 03:10 PM   #7
Mike Mercury
CF Senior Member
there is no speedometer error when changing rear gear ratios on the C5.
and yes; the HPIII does fail at gear scaling on the C5 (anything past the 3.15 ratio). Hypertech admits the errror, ands says they will do nothing to correct it. Their method works on F-Bodies just fine, but not the (somewhat) unique C5.
Old 01-02-2006, 08:52 PM   #8
502ci
CF Senior Member
502ci's Avatar
I stand corrected, I was assuming that when I put in some 4.10`s(haven`t yet) that I could play with the tire size (with the hypertech)till I got it corrected. Thanks for the info.
Reload this Page hypertech controller????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Installed NEW '04 t-stat & fan controller - Still have ? LBear C5 Tech 14 04-13-2004 03:06 AM
Hypertech Programmer 1969stingray1969 C5 Tech 15 12-28-2003 01:03 PM
Quick hypertech question. MagikDraggin C4 Tech/Performance 12 04-05-2003 04:18 PM
Hypertech users please speak up corvette Mark C5 Scan & Tune 15 02-27-2003 08:45 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
