Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-23-2005, 12:12 AM   #1
crazygn
CF Senior Member
Default does a tune go bad or change
when i bought my car i was told it was tuned but ran real bad, i was told it needed to be retuned. Well i had it tuned and ran good but seems to be dead at part thottle now and idle jumps around some times now, and it did back fire out the pipes the other day.
Does a tune change after time, i didnt think it did , how does it do this or why
crazygn is offline   Reply With Quote
Old 11-23-2005, 01:13 AM   #2
bshell
CF Senior Member
bshell's Avatar
Tunes do not go bad. They are what they are, you had a bad tune to begin with and it just took awhile to affect driveability. You do not specify how your car was "retuned". If it was tuned on a dyno then there is a good chance that part throttle was untouched or just glossed over. My advice would be to find a different tuner or purchase a tuning suite on your own. Keep in mind that a part throttle tune takes longer and will therefore cost more if you have a pro tune it for you.
bshell is offline   Reply With Quote
Old 11-23-2005, 02:04 AM   #3
crazygn
CF Senior Member
it was tuned on a dyno and put 3 passes on it there. the car when i cruise in like a higher gear seems dead down low and you need to give the car a lot of gas to get the car to move. I know he said he pulled some timming out up high and put some in mid that all i know.
Old 11-24-2005, 12:33 AM   #4
CAPTKEN28
CF Senior Member
It sounds like its time to change your plugs.....
CAPTKEN28 is offline   Reply With Quote
Old 11-26-2005, 02:20 PM   #5
crazygn
CF Senior Member
i just put ngk 6 plugs i think thaey are in [colder then stock ] about 500 miles if that .
thanks
Old 11-26-2005, 08:34 PM   #6
ST0CKER
CF Senior Member
tunes can and do change based on the season.
Dave
ST0CKER is offline   Reply With Quote
Old 11-28-2005, 02:12 AM   #7
bshell
CF Senior Member
bshell's Avatar
I agree that tunes do change (slightly) with the season, but not enough to make a "good" tune go "bad".
I think the seasonal tune change is more due to changes in available fuel and not due to the tune itself. I know of cars that were thoroughly SD tuned in the summer and rechecked in the winter to be within 2% (via fuel trims) of the summer tune, so it can be done.
Old 11-28-2005, 02:15 AM   #8
bshell
CF Senior Member
bshell's Avatar
Quote:
thanks
Was there any specific reason you went with the TR6 plugs? What were they gapped at? You could throw in some TR55s to see if that clears up some of the problems you've been having.
Old 11-29-2005, 05:18 PM   #9
macsperformance
CF Member
macsperformance's Avatar
If your vehicle was mapped properly in the first place these issues would not be present. This is why the modern fuel injection systems of today adjust for conditions such as changing air density like it was spoke about above by using sensors such as MAF, MAP, and IAT.
Chris Macellaro
macsperformance is offline   Reply With Quote
Old 11-30-2005, 01:34 AM   #10
Bink
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '09
Bink's Avatar
Tunes do not go bad. They are not transient.
However airflow, timing (limited), and fuel "learning" does occur. If a tune is not correct, and accurate, as the car "learns" with driving time it's manners may deteriorate. The tune did not "go bad" - it was inadequate from the start.
__________________
There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games. - E. Hemingway
Bink is offline   Reply With Quote
Reload this Page does a tune go bad or change
Tags
bad, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Does anyone have Andy's Head/Cam special? MagRed01Atty C5 Tech 17 05-19-2004 09:01 PM
MSD went bad what should I buy now? vettef6 C4 Tech/Performance 34 07-24-2003 08:20 AM
Looked at a 1993 Corvette today Tolofou C4 General Discussion 19 03-07-2003 05:43 PM
Does the VaraRam filter come pre-oiled? Mine is bent up rbartick C5 Z06 Discussion 16 09-03-2002 08:17 PM
Should I change my PCM? steveelsbury C4 Scan & Tune 14 06-22-2002 06:11 PM
Looking for that special Corvette gtpclub C4s for Sale/Wanted 2 07-26-2001 12:00 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
