Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2005, 10:18 PM   #1
Doczo6
CF Senior Member
Doczo6's Avatar
Default Part throttle timing? WIth HP tuners
Anyone have any pointers on the best way to adjust (lower) timing at 50% throttle (part throttle), I am fine WOT timing wise but getting some knock at 50% throttle. THis is with HPtuners. Thanks for any help
Terrance
Doczo6 is offline   Reply With Quote
Old 11-22-2005, 02:48 PM   #2
Doczo6
CF Senior Member
Doczo6's Avatar
anyone?
Old 11-22-2005, 04:05 PM   #3
bshell
CF Senior Member
bshell's Avatar
You can adjust part throttle timing through the high/low octane timing tables. They are rpm and g/cyl based and do not reference tps. Take a look at your kr and advance histograms to see at what g/cyl and rpm you are getting kr and what your advance is at that rpm. You can then lower the affected cells to see if it helps.
Also take a look at your logs to see what ftc you are falling into at 50%. It could be that you are entering PE at certain rpms at 50% throttle. If you are entering PE, take a look at your commanded afr for the rpm range you are getting kr to make sure its not too lean.
What is your total advance when you are getting kr? And at what rpm?
bshell is offline   Reply With Quote
Old 11-22-2005, 04:07 PM   #4
C5kid
CF Senior Member
Cruise-In VI Veteran
C5kid's Avatar
Send a message via AIM to C5kid
do you have a FI car? cause I have a great timing table if you do... no knock and it is very smooth
C5kid is offline   Reply With Quote
Old 11-22-2005, 10:38 PM   #5
Doczo6
CF Senior Member
Doczo6's Avatar
Thanks for both of the replies Its mainly from 1000-2400rpm's and .36 airflow. I did like you said and pulled some timing in these cells I will log and see if it takes care of it, yes its a procharged 408 stroker. Thanks again and I would love to see the file
Terrance
Reload this Page Part throttle timing? WIth HP tuners
Tags
adjustment, buck, hp, hptuners, part, setting, smooth, throttle, timing, timming, tune, tuner, tuners, tuning, ve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LS2 tuning software update JJFormato C6 Tech/Performance 44 10-04-2005 01:55 PM
You guys are going to fall over laughing. '06 Quicksilver Z06 C5 Scan & Tune 12 06-03-2005 07:37 PM
Cams - R U running a 228/588 @ 114 LSA? LeMansBlue04 C5 Tech 43 10-06-2004 11:34 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
