Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2005, 03:01 AM   #1
liqwid_vette
Junior Member
Default Getting Code P1516 after Shaner TB and Halltech Stinger
I installed a Shaner ported TB and Halltech Stinger on my 98 C5. I am getting a PCM code 1516 often. "Reduced Engine Power" on DIC and car has no power. I pull over, clear code and runs fine. Will a dynotune fix this problem or is there something wrong with TPS sensor. Anyone else had this problem? TIA for any help. It is greatly appreciated. Thanks, Jeremy.
liqwid_vette is offline   Reply With Quote
Old 11-21-2005, 09:13 AM   #2
ToplessTexan
CF Senior Member
Cruise-In II Veteran
ToplessTexan's Avatar
Sounds like the PCM is not seeing the voltages at the TPS that it expects. Are you seeing this at just extreme throttle positions? I recall seeing people fiddling with getting these adjusted, try a search. It sounds too me like a TB issue, not tuning.
ToplessTexan is offline   Reply With Quote
Old 11-21-2005, 09:45 AM   #3
ToplessTexan
CF Senior Member
Maybe something along these lines:
http://forums.corvetteforum.com/show....php?t=1121001
Ignore the predicted airflow flow comments there, they're relevant only if you're seeing a P1514, not a P1516.
One other thought is that there was a TAC module service bulletin ages ago that addressed a condition that would trigger this code. I doubt that's your issue and that your car has had that update, but something to be aware of.
Old 12-13-2005, 08:53 PM   #4
Blown-Interceptor
CF Senior Member
Blown-Interceptor's Avatar
I am getting the same P1516 code. TB is stock, anyone know the part number I might need?
Thanks,
Jason
Blown-Interceptor is offline   Reply With Quote
Reload this Page Getting Code P1516 after Shaner TB and Halltech Stinger
Tags
code, corvette, fix, p1516, ported, tracking, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
