Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2005, 11:53 AM   #1
BuzzZo6
CF Member
Default Can this be tuned away?
My current motor is a ls6 replacement crate motor that was sent by Chevy to replace the stock ls6 that broke under warranty. I had installed a set of Patriot ls6 cnc style heads with stock compression and combustion chambers. I am using Patriot's 226/226 112lsa .585 lift cam. I also installed a ported throttle body. After the motor was tuned the tuner stated that if the motor continued to surge at idle with the ac on or continued to stall when coming to a stop in traffic to drill a hole in the throttle plate. Well I dont believe drilling a hole in the throttle plate will stop the surging. I contacted the machinist that sold me the throttle body, this guy has over 30 years of building all sorts of motors, he told me to absolutely not to drill the hole in the throttle that the surging at idle should have been taken care of with the tuning. And if I remember correctly there is a hole drilled from the factory in f-body throttle body plates, well no insult meant to the f-body guys, this is a Corvette Zo6 not a Trans-Am or Camaro.
BuzzZo6 is offline   Reply With Quote
Old 11-20-2005, 01:37 PM   #2
78Vette-SA
CF Senior Member
78Vette-SA's Avatar
Drilling a hole in vette TB's is common practice to get a cam car to idle and reduce surging. You can tune around it, but from experience I can tell you it hurts nothing and makes life much easier. I drill them as a starting point for tuning many times. Especially if the cam is on the stout side.
However, you still need to fine tune idle, surging and stalling out. Whether you drill the TB or not, tuning is required to make the car run right and it can be done given your combination of goodies.
I'm sure if you asked 100 people 50 would say drill it and 50 would say don't.
__________________
Email: Joe Santacroce
98 Black A4 Coupe Heads/Cam/N2O - 81 FrankenSport LS6SC/6spd/SRIII
78Vette-SA is offline   Reply With Quote
Old 11-23-2005, 10:45 AM   #3
DTSNGIT
CF Senior Member
DTSNGIT's Avatar
I haven't ever found a reason to drill a hole in a Vette TB. You can 100% of the time tune around this if you have reasonable experience. Now on some F-Bodies drilling a larger hole might be the answer but not with the Vette and fly-by-wire TB.
You need to visit another tuner with more experience...........
Mike
DTSNGIT is offline   Reply With Quote
Old 11-23-2005, 11:26 AM   #4
see5
CF Senior Member
see5's Avatar
Lots or maybe most tuners can tune much bigger cams than that without drilling. Drilling is a Fbody (no motor drive TB) remedy.
__________________
2000, 6M, Kinesis rims, VBP springs, Bilsteins, Poly bushings, CCWs -315/335 Hoosiers, (SM2), Cross-bar, G-Force harness, Sparco EVO 2 seat, forged, stroked LS7 (441CI), Halltech, Blackwing, Shaner TB, PowrMAF 100, LS3 intake, ported LS3 heads, not too much cam, Fast 50# injectors, C6 oil pan, Accusump, RPS Twin CF clutch, Kooks 1 7/8" headers, 3" catless midpipes, Z06 TIs, hardened 3.90 rear, EFILive V2, LM-2 wb, always tuning.
see5 is offline   Reply With Quote
Old 11-23-2005, 01:54 PM   #5
RPO_Z06
CF Senior Member
Cruise-In III Veteran
St. Jude Contributor
RPO_Z06's Avatar
Send a message via AIM to RPO_Z06
My cam is WAY bigger than that and I have ZERO surging issues and NO hole drilled in my TB plate.
DON'T drill it, Tune it...
__________________
'01 Speedway White Mod/Red Z06
Too many mods to list.
RPO_Z06 is offline   Reply With Quote
Old 11-23-2005, 03:26 PM   #6
vetpet
CF Senior Member
Do not drill a hole in you TB. The issue you're experiencing can be tuned out.....it just takes a bit more time and experience. There are a lot of cars running bigger cams that don't have that problem.
vetpet is offline   Reply With Quote
Old 11-23-2005, 06:34 PM   #7
Roofless
CF Senior Member
St. Jude Donor '11
Roofless's Avatar
Send a message via AIM to Roofless Send a message via Yahoo to Roofless
I had the same problem on my blower car and couldn't get it right no matter what I did. I took it to A&A in CA and they fixed it up with tuning no hole drilled in TB it ran and still runs great, no stalling or surging at all.
Roofless is offline   Reply With Quote
Old 11-23-2005, 09:12 PM   #8
Fastbasser
CF Senior Member
Fastbasser's Avatar
Alot of folks (and shops) drill the TB. It's no big deal. Yes, it can be done without it but in all honesty, why bother spending alot of time tuning when drilling it makes most cars drivable. It will need a final tune though.
Cuts time, saves money and hurts nothing!
JMHO
Fastbasser is offline   Reply With Quote
Old 11-25-2005, 02:38 PM   #9
Y2KVert
CF Senior Member
St. Jude Donor 06
Y2KVert's Avatar
JMHO
Why waist time doing it right? Drilll a big hole in it and worry about it later.
Take it to somone who knows how to tune it. You spent the money to get it this far do it right and tune it.
__________________
Cammed and slammed 2000 C5 Vert
241 Casting Stage II heads w/ comp 921 dual spings
Comp 224/228 - 581/583 112 lsa
ASP pulley
LS6 oil pump
Kook's headers , Kook's 3" x-pipe w/ cats
SLP Powerflow exhaust
Haltec Stinger, LS6 intake
160 thermostat
18 & 19" I-forged Swifts, BFGoodrich TA KDW2 rubber.
3.90 gears w/DTE strut brace.
Tuned by: Nick Steffens (BLOWNZ06)
Y2KVert is offline   Reply With Quote
Old 11-25-2005, 03:11 PM   #10
78Vette-SA
CF Senior Member
78Vette-SA's Avatar
Quote:
Lots of experts out there.
Like I said the first time, ask 100 people and you'll get as many different answers. The original question was can it be tuned. Part of my first response was "Whether you drill the TB or not, tuning is required to make the car run right and it can be done given your combination of goodies".
Movin' on...
__________________
Old 11-25-2005, 07:02 PM   #11
Fastbasser
CF Senior Member
Fastbasser's Avatar
Looks like we have another "internet expert" here
Oh by the way, 414 hp isn't much for your mods .
JMHO
Old 11-26-2005, 01:54 PM   #12
Y2KVert
CF Senior Member
St. Jude Donor 06
Y2KVert's Avatar
JMHO
Sorry haven't updated my signature lately. It makes considerably more power now.
WE DRILLED A HOLE IN THE TB AND IT PICKED UP A BUNCH OF POWER!
Old 11-26-2005, 01:56 PM   #13
Y2KVert
CF Senior Member
St. Jude Donor 06
Y2KVert's Avatar
JMHO
Oh and I learned allot of info on these cars while lurking and reading your imformative posts.
__________________
ASP pulley
LS6 oil pump
160 thermostat
Old 11-26-2005, 05:54 PM   #14
Fastbasser
CF Senior Member
Fastbasser's Avatar
Musta got ta ya... Ya had to make back to back posts!!
LMAO
Old 11-26-2005, 06:08 PM   #15
Y2KVert
CF Senior Member
St. Jude Donor 06
Y2KVert's Avatar
LMAO
Nah not at all. Carry on there super tuner!
__________________
ASP pulley
LS6 oil pump
160 thermostat
Old 11-26-2005, 07:09 PM   #16
Fastbasser
CF Senior Member
Fastbasser's Avatar
Heh heh heh,,, I see I made ya had ta go back and raise your HP/torque numbers on your profile ..
I must be a super tuner!!!! I can make your numbers go up just by making a post!
I guess I'll go back and do mine... HMMMM What shall I pick, what shall I pick???? I'll pick 509.9 hp and 470 lb/ft of torque.. (w/o the 100hp n2o shot)
Though I'm having fun, I gotta let this thread go.
Have a great day!
Old 11-26-2005, 10:37 PM   #17
Y2KVert
CF Senior Member
St. Jude Donor 06
Y2KVert's Avatar
Have a great day!
and your only in the 11 sec club? Maybe it needs a little more tuning work. With those numbers it should be quicker.
Old 11-27-2005, 08:43 AM   #18
see5
CF Senior Member
see5's Avatar
Let it go boys.
Old 11-30-2005, 01:44 AM   #19
Bink
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '09
Bink's Avatar
Quote:
Originally Posted by see5
Let it go boys.
FWIW. My cam...239/251, 106 lsa.
I've done it both ways..with and without a drill.
Idle Transition tuning seems to be a little more accurate without the hole.
I do my tuning.
__________________
There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games. - E. Hemingway
Bink is offline   Reply With Quote
Old 12-27-2005, 10:48 AM   #20
TrueBlueCoupe
CF Senior Member
TrueBlueCoupe's Avatar
Quote:
No holes in the F-bodies from the factory, must be a myth. And careful what you say about F-bodies. My WS6 would run with the Corvettes at the track and cost less to keep it going. ( Once I put a Turn One power steering pump in, the first 3 OEM pumps were not cheap)
TrueBlueCoupe is offline   Reply With Quote
Reload this Page Can this be tuned away?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steal this 99 6spd vert...with Supercharger TANGLVR C5 Corvettes for Sale 34 07-23-2005 09:21 AM
.32 away from my all motor goal need some help..... Phil97SVT C5 Tech 10 04-09-2003 01:05 AM
I can't stop smiling!!! carter200 C4 ZR-1 Discussion 31 08-15-2002 12:08 PM
Donaldson on an '02 may be a no no! Lawdogg C5 Tech 61 10-24-2001 03:06 PM
one mean tuned port mod 88L98 C4 Tech/Performance 55 10-16-2001 09:39 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
