Quote:
Originally Posted by JEEP/C5
Has anyone run with TM off for a couple of years and had problems with tranny? If so - do you race? And what kind of problems?
I use LS1 edit so I don't know what +or - 5 means but suffice to say that if you add as little as 5% shift pressures you'll feel the shifts (which most like) and as reported to me by a well known trans shop that's just fine.
As for TM. Many have ideas in either direction but eliminating it really wakes the car's responsiveness up and I've seen no degredation in any transmission related to TM being disabled. Transmissions fail for a number of things -- mostly high temperatures. When you add 100hp at the crank, sure the transmission will fail earlier than if you have left everything alone (stock).....but that's no fun is it?
