Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2005, 05:53 PM   #1
YELLOHHH
CF Senior Member
YELLOHHH's Avatar
Send a message via AIM to YELLOHHH
Default Help Needed!!!
P 1220 & P1221.
Codes will NOT clear. Car stays in reduced power mode and is undriveable. Has happend a few times in the past, but was very random. WHAT DO I DO???
YELLOHHH is offline   Reply With Quote
Old 11-05-2005, 08:09 PM   #2
98GreenC5
CF Member
98GreenC5's Avatar
p1220 is throttle position sensor,
p1221 is throttle position sensor 1-2 correlation.
check the connector and wires the sensor(passenger
side of the throttle body) .
These codes check for the relationship between
the throttle pedal and the throttle position to
see that the throttle blade opening agrees with
the pedal.
Hope this helps.................
__________________
98 Fairway Green Coupe
ECS 408,Halltech Trap
3:42 ,Yank ST3500 , Rossler trans
Best ET 10.72 , Best MPH 126.74 @ MIR 3/30/07
98GreenC5 is offline   Reply With Quote
Old 11-06-2005, 03:47 PM   #3
YELLOHHH
CF Senior Member
YELLOHHH's Avatar
Thanks Dick, I'll check all that stuff today. Hope all is well.
Anyone else deal with this before?
Old 11-07-2005, 11:01 AM   #4
YELLOHHH
CF Senior Member
YELLOHHH's Avatar
Dick, you called it. I unplugged the sensor, cleaned it up a bit and plugged it back in. Problem seems to be solved. Thanks again!!!
Old 11-08-2005, 10:26 PM   #5
NoOne
CF Senior Member
Quote:
Check the connection to the TPS sensor(Passenger side of TB), clean the grounds on the chassis you can see, and follow the harness from the TPS sensor back to see if there are any cuts or kinks.
Nah dude, that can't be it
__________________
"You have enemies? Good. That means you've stood up for something, sometime in your life."
Winston Churchill
NoOne is offline   Reply With Quote
Reload this Page Help Needed!!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Urgent help needed to uncover Vette Essentials conspiracy at Carlisle! SteveL2 C6 Corvette General Discussion 20 08-31-2005 10:52 AM
Ebay purchase help needed Ras119 C4 General Discussion 27 08-15-2005 11:35 PM
Pinging in Las Vegas-Help needed PUREFUN C5 Scan & Tune 11 08-01-2005 11:11 PM
Disaster at the Chevy Dealership JF_AH_64 C4 Tech/Performance 53 09-28-2004 12:07 AM
Pulse Wiper Help needed Curtis629 C4 Tech/Performance 21 03-17-2002 02:09 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
