Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2005, 03:41 PM   #1
muncie21
CF Senior Member
muncie21's Avatar
Default MAF and Lean condition question
OK, so my FI car (99 NI Maggie) was running lean on the Dyno. Installed a Kenne Bell boost a pump to keep the FP up around 58 or so PSI. No difference. Then for grins I disconnected the MAF and bamm!! MY AFRs come down from 13.5 to 12.1 to 11.8, perfect. sooo, what the heck is wrong with the MAF? Do I have a bad MAF or are the settings in the VE table incorrect? More importantly, how the heck does one go about troubleshooting this issue?
muncie21 is offline   Reply With Quote
Old 11-26-2005, 10:31 PM   #2
jers98vet
CF Senior Member
jers98vet's Avatar
Try cleaning the maf with some brake cleaner and take some a/f readings again. A dirty and/or oily maf will cause irratic readings.
jers98vet is offline   Reply With Quote
Old 11-27-2005, 02:35 AM   #3
78Vette-SA
CF Senior Member
78Vette-SA's Avatar
Quote:
Also, was this at WOT or across the rpm range? I'd work on the injector flow rates and the VE table to get your LTFT's (long term fuel trim cells) in line (0 to around -8). If it was lean with a Wideband O2 at WOT then I'd also work on the PE Multiplier table along with the above (and timing) as a starting point.
__________________
Email: Joe Santacroce
98 Black A4 Coupe Heads/Cam/N2O - 81 FrankenSport LS6SC/6spd/SRIII
78Vette-SA is offline   Reply With Quote
Old 11-27-2005, 03:20 AM   #4
chriswtx
CF Senior Member
chriswtx's Avatar
Send a message via AIM to chriswtx
Sounds like you need to adjust the PE table and add some fuel at WOT and see if it changes first. Was this an out of the box tune or is your tuner having problems with making changes and nothing happening??
chriswtx is online now   Reply With Quote
Old 11-27-2005, 02:37 PM   #5
muncie21
CF Senior Member
muncie21's Avatar
Quote:
This was an out of the box Magnuson tune. Prior to the mag install my AFRs were around 12.2-12.5 with the stock motor at WOT on the Dyno. With the MAF on (and the Maggie on) I wasn't able to get below 13.5 AFR at WOT on the Dyno. I installed the BAP, no change. Disconnect the MAF, and was getting 11.8-12.2 at WOT. The upper RPM ranges in the PE table are something like 1.13 to 1.11.
I don't have access to a good tuner package so I'm basically changing things one at a time and taking it to the dyno to see what happens. This is getting kinda expensive so I've got the MAF disconnected right now until I get the money for HP Tuners.
Old 11-28-2005, 02:27 AM   #6
bshell
CF Senior Member
bshell's Avatar
Ok, I've got a few questions for you:
1. What size injectors are you running and what were the injector duty cycles on the dyno?
2. Do you know what parameters the Maggy tune altered?
3. Is your MAF an untouched stock unit? (no porting, descreening, etc)
4. Was fuel pressure monitored on the dyno?
The PE values you listed above, 1.13 - 1.11, do not correspond to 11.8 - 12.2. They calculate out to be 13.0 - 13.2 (14.7/1.11 and 14.7/1.13). These #s look more like a standard tune to lean out the stock settings for some extra hp. If no changes were made to the PE or OLFA tables then this is why AFR wouldn't lower (assuming fueling is adequate).
bshell is offline   Reply With Quote
Old 11-28-2005, 02:33 AM   #7
chriswtx
CF Senior Member
chriswtx's Avatar
here is my PE table. I am at 11.3-11.5 at WOT
1.207 1.207 1.207 1.207 1.206 1.228 1.241 1.244 1.261 1.265 1.275 1.279 1.284 1.281 1.29 1.301 1.301 1.301 1.301
Old 11-28-2005, 02:35 AM   #8
chriswtx
CF Senior Member
chriswtx's Avatar
This PE tab le had me at 11.9-12.0 WOT
1.202 1.202 1.202 1.2 1.199 1.213 1.214 1.217 1.219 1.223 1.229 1.234 1.242 1.239 1.248 1.258 1.258 1.258 1.258
Old 11-28-2005, 02:42 AM   #9
bshell
CF Senior Member
bshell's Avatar
Quote:
The first thing you should do is to have your PE values set around 1.2x, this will ensure that you will run a safe AFR.
It sounds to me that your VE table is too lean. This skews your fuel trims positive under part throttle conditions (+ trims = pcm adds fuel). When you go wot with positive fuel trims, the pcm will add extra fuel to prevent a perceived lean condition. The fact that it only goes rich with the MAF disconnected would make me look at VE first. Once the VE table is adjusted to go slightly rich under part throttle (negative fuel trims), then the MAF table will need to be readjusted.
Here is a link to a good maggy tune that either you or your tuner can use as a starting point for your car:
http://www.horist.com/hptuner/search.asp?action=exe
Old 11-28-2005, 10:57 AM   #10
muncie21
CF Senior Member
muncie21's Avatar
Thanks for all the input guys
I guess I need to take the plunge and pick up HP Tuners so I can see what's going on inside my motor. I'll post, either more questios, or the solution, once I get the tuner in my hands.
Old 11-28-2005, 11:37 AM   #11
chriswtx
CF Senior Member
chriswtx's Avatar
I love my HP tuners. I have the optional EIO cable and the LM1 wideband oxgen sensor. HP tuners can log the data from the wideband. Its really a fantastic feature...
Reload this Page MAF and Lean condition question
Tags
1207, bad, corvette, hp, lean, maf, pe, ratio, tuners
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ram Air - Myth or Truth? 300bhp/ton C5 Tech 242 06-19-2011 05:39 PM
Exhaust Question, Remove the Cats? mk1spyder C5 Tech 19 03-17-2004 01:20 PM
MAF Screen...Keep or Remove? Facts only please! Mean In Green C5 Tech 16 05-10-2003 11:24 PM
MAFT Tuning question... WOT detonation with 13/1 A/F ratio CAracer C5 Tech 10 06-29-2002 08:25 PM
2002 airbox question... WWK888 C5 Z06 Discussion 16 03-14-2002 01:45 AM
Granatelli MAF Sensor Question SteveSz C5 Tech 27 12-04-2001 11:19 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
