Thanks Purrv, Would it help me to look at some of the example tune files and log files that came with EFI first? From everything I've read so far the LTFT table is what you want to look at first but when I look at the table the cells are in % format. Can these values be converted to a positive or negative whole number? My understanding is that you want the numbers to be either slightly negative or zero in the cells so that you don't add extra fuel at WOT to the PE table. I'm probably jumping ahead of myself but do you make your cell changes in the logged map table and then copy and paste it into the tune map table for downloading into the PCM?
Thanks for helping a newbie.
