Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-31-2005, 07:52 PM   #1
NavyVet
CF Senior Member
NavyVet's Avatar
Default Turn off 'Service Tire Monitor' msg on a 99?
Title says it - can this be turned off?
Thanks a lot, Paul
NavyVet is offline   Reply With Quote
Old 10-31-2005, 08:01 PM   #2
mdhmi
CF Senior Member
Support Corvetteforum!
mdhmi's Avatar
Send a message via AIM to mdhmi Send a message via Yahoo to mdhmi
Not according to the tuners I've spoken with.
I checked because I wanted to find a way to disable the low pressure warning when I run my DR's in kill mode.
Mark
mdhmi is offline   Reply With Quote
Old 10-31-2005, 11:47 PM   #3
RPO_Z06
CF Senior Member
Cruise-In III Veteran
St. Jude Contributor
RPO_Z06's Avatar
Send a message via AIM to RPO_Z06
Yes with a Tech II you can enable or disable this.
__________________
'01 Speedway White Mod/Red Z06
Too many mods to list.
RPO_Z06 is offline   Reply With Quote
Old 11-01-2005, 04:36 AM   #4
fdxpilot
CF Senior Member
fdxpilot's Avatar
Mike Frey
Send a message via AIM to fdxpilot
Quote:
Only on 01 and up cars. With the advent of the Z06, with it's non-runflat tires, they had to program the computer to allow that feature to be disabled. 97-99 cars are out of luck.
fdxpilot is offline   Reply With Quote
Old 11-01-2005, 10:51 AM   #5
CrazyChris
CF Senior Member
What if you rewrote a '99 or '00 PCM with a '02 bin, could you then turn it off of the older car?
CrazyChris is offline   Reply With Quote
Old 11-01-2005, 12:53 PM   #6
boosted_z06
CF Senior Member
Quote:
Changes would have to be made in the BCM not the PCM and if you flashed the BCM from a newer year then the key fobs would not work since the electronics changed on 2001
boosted_z06 is offline   Reply With Quote
Old 11-01-2005, 01:15 PM   #7
MTurnbo
CF Senior Member
MTurnbo's Avatar
Quote:
What about the 2000?
MTurnbo is offline   Reply With Quote
Old 11-01-2005, 02:07 PM   #8
fdxpilot
CF Senior Member
fdxpilot's Avatar
Mike Frey
Quote:
Sorry, shoulda read "97-00 are outta luck." And unfortunately, as mentioned above, since it's the BCM that contains this code, a tuner can't change it.
Old 11-01-2005, 03:19 PM   #9
CrazyChris
CF Senior Member
That really is a disappointment. I have been fighting that stupid message for over a year now. Anything pre-01 cars can do?
Old 11-02-2005, 12:19 AM   #10
NassauBlue98
CF Senior Member
NassauBlue98's Avatar
I think if you take the pressure sensors out of all the tires the computer won't throw the message. I noticed this because I threw my old wheels and tires on to autocross last summer and noticed the dash never threw the code (and the wheels don't have sensors in them).
I'm considering taking all my sensors out. The message seems to be more of a pain than it is worth.
I've got a whole slew of codes I wish I could program out... low coolant, tire pressure, ride control, etc.
NassauBlue98 is offline   Reply With Quote
Old 11-02-2005, 01:02 AM   #11
CrazyChris
CF Senior Member
I usually drive on my CCW setup and none of the wheel sensors are present. It throws the code every time. The reason you didn't have it come up during your autocross is that you have to drive x number of miles with no sensors before it will throw the code on the display. If there is anything we can do to get around this I'm all ears.
Old 11-02-2005, 02:45 AM   #12
MUKAK
CF Senior Member
YEP EXATLY!!!
Mines comes back every 60 miles or so, then i clear it.
on 97-00 cars u cannot do anything about it
MUKAK is offline   Reply With Quote
Old 11-02-2005, 12:58 PM   #13
CarsRFun
CF Senior Member
CarsRFun's Avatar
pure.. gayness.
CarsRFun is offline   Reply With Quote
Old 11-02-2005, 08:02 PM   #14
DrSagan
Junior Member
Seems a simple circuit could overcome this. I assume these are three wire sensors?
DrSagan is offline   Reply With Quote
Old 11-02-2005, 09:37 PM   #15
NassauBlue98
CF Senior Member
CrazyCarl,
Thanks for the response. I was just thinking tonight I need to take the wheels off the car and take them in to get the sensors taken out. I guess now I will think harder about buying a new sensor (I assume you have to buy a new one for $75, or is there a battery or something in them that is replaceable?).
DrSagan,
That would be fantastic! I don't know the details on it. Maybe the Service Manual would give some clues...
Old 11-03-2005, 11:29 AM   #16
Gordy M
CF Senior Member
The 97-00 cars had the TPS in the firmware on the PCM. Unless you know someone in GM to rewrite your code, you cannot turn it off. No, I do not know anyone who can do it, but I tried. With the 01-04 they moved the code to the programmable area because of the Z06. For 05 1/2 they moved it to the TCM firmware and made the TC/AH part of the program.
We can still take the TPS from the rims and live with the code.. the new cars go to reduced power mode.
Gordy M is offline   Reply With Quote
Old 11-03-2005, 02:31 PM   #17
NavyVet
CF Senior Member
NavyVet's Avatar
Default Thanks to all
I will try to learn to live with the code. I get it at start-up and shut-down always. It also sometimes recurs while driving, but that seems to be random???
Old 11-06-2005, 05:28 AM   #18
DrSagan
Junior Member
The little bit of research I did on this points to that the pressure sensors produce a varying frequency based on pressure and evidently the BCM reads this. What I don't know is whether the BCM turns the light on, or whether it communicates with the PCM which stores the code and sets the light. Anyone know?
Gordy, you mentioned the pressure stuff is hardcoded in the firmware and it can't be changed. The operating system and the lookup tables/settings are all stored in flash so, although not a trivial task, the operating system could be disassembled, edited, and reassembled to remove this(harder) or just widen the ranges(easier ) I just need more info before I would attempt the countless hours needed to do this.
Reload this Page Turn off 'Service Tire Monitor' msg on a 99?
Tags
1997, 2005, 99, c5, corvette, disable, light, moniter, monitor, monitoring, service, shut, system, tire, turn, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
