Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-14-2005, 02:55 PM   #1
speedz06
CF Senior Member
Default AFR guage wired into stock system
Wich is better the set ups that wire into the stock system or the ones like the dynojet kit.there is one for sale on the forum I will buy if it will work.does anyone have experience with this stuff?
speedz06 is offline   Reply With Quote
Old 08-14-2005, 04:26 PM   #2
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Quote:
if I understand you correctly...
the stock O2 sensors are narrowband. Great for non-racing AFR readings but are not sensitive enough to check WOT AFR. Most aftermarket AFR meters are made for wideband O2 sensors that have a 0-5 volt output (narrowband sensors output 0-1 volt).
Mike Mercury is offline   Reply With Quote
Old 08-31-2005, 10:53 AM   #3
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
Mike
I think he is asking if the wide band sensor can be installed inplace of the narrow band O2 sensor and can be made to work with the stock system and also have the functionality of the wide band recording device.
BC
Bill Curlee is offline   Reply With Quote
Old 08-31-2005, 07:44 PM   #4
Patches
CF Senior Member
Patches's Avatar
You can go either way but I personally wanted to keep my WB and NB functions separated in case the WB failed. That way, I would be left stranded somewhere trying to find and install a replacement NB.
Most of the WB setups will emulate your NB O2 sensor so you can replace the stock unit with the WB and get both NB and WB functions simultaneously. It's not always easy to get the NB function working smoothly. I installed a PLX 250 WB setup. Here's a link to my installation.
PLX WB O2 installation
Patches is offline   Reply With Quote
Reload this Page AFR guage wired into stock system
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
