Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-11-2005, 11:31 AM   #1
jwg2
CF Senior Member
Send a message via ICQ to jwg2 Send a message via AIM to jwg2
Default OBD II and Va. Emissions Inspection
Took my Z06 in for its first ever Virginia Emissions test this past week. I was puzzled by the fact that the inspector never put the car on the dyno and never put a sniffer in the tail pipe. The only thing he did was plug the testing unit into the OBDII connector under the dash. My test results came back all n/a for HC ppm, CO%, and NO ppm at both 15mph and 25mph, and an official "PASS".
I've taken other OBDII cars through inspection and always got sniffed. Turns out Virginia now has a test that uses your stored data to determine if your car is 'clean'
More info is here. http://www.deq.state.va.us/mobile/mobobd.html
After reading it, it looks like its just checking to see if you've run through a series of use cases the OBDII monitors and if those use cases throw codes. My guess is you could get car with problems through just by resetting your DTCs before you get the car inspected.
As an aside, one of the local papers here ran an analysis of all VA emissions inspections on cars 5 years and newer, and found only 0.6% failed (or about 200 cars).
jwg2 is offline   Reply With Quote
Reload this Page OBD II and Va. Emissions Inspection
Tags
emissions, obd, scan, virginia
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
OBD II and Va. Emissions Inspection jwg2 C5 Tech 10 08-14-2005 09:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
