Found this on the HP Tuner forum RE: the enhanced IO interface...
Quote:
What does the Enhnaced IO interface allow me to do?
With our EIO interface, you can use 0-5v signals from various sensors such as EGT, Wide Band, fuel pressure and others for sensor input in our scanner. You will have real time data from those sensors right next to your standard scan tool data such as TPS, RPM, MPH, etc.
So you need to pay another $150 to do wide band O2 tuning with HP Tuners whereas you can do this out of the box with EFI Live which puts the prices more in line with each other. I doubt that Tuner Cat will do wide band tuning at all.
