Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-03-2005, 11:09 PM   #1
STA-BLK
CF Senior Member
STA-BLK's Avatar
Default Installed maf translator.Runs Great but ltft's are high
Ive been having problems with my car not running up to par since i had mti do some work.I took it into my own hands to get the tranny shifting correctly but i never got as much power as i thought i could.I installed a maft and did a relearn and WOW>I think i may have leaned it out too much but im getting NO kr at all.Problem is my ltft's are 15 and 13.What is a possible problem that could make it run thid much better with this high of trims?
STA-BLK is offline   Reply With Quote
Old 08-05-2005, 06:09 PM   #2
INTHERED
CF Senior Member
INTHERED's Avatar
Send a message via ICQ to INTHERED Send a message via AIM to INTHERED
I used a MAFT on my car for a while and if my memory is serves me correctly there are 2 adjustment knobs one for cruise or idle(closed loop) and one for WOT (open loop). It gets kinda tricky since the two adjustments interact. You need to get the fuel trims reading between 0 and -6 during closed loop operation first. So since your fuel trims are at +15 turn the first knob in the rich direction. It would be nice to have an air/fuel meter or a dyno to verify which way to adjust the second knob while running the car at WOT. You will need to put at least 100 miles on the car after a gas fillup under a variety of conditions to get the fuel trims stable. I usually view the fuel trims cruising steady at 60 or 70 on the hiway and also at an idle.
INTHERED is offline   Reply With Quote
Old 08-07-2005, 07:20 PM   #3
tici
CF Member
tici's Avatar
Why did you install the MAFT? What about LTFT before installing it?
I used to have one of them without wideband: WOT tuning is just a guess.
Closed loop is ok.
Also the MAFT is known to have a "lean hole" at 4000-5000 rpm.
You can modify it adding a capacitor (there is a description at vetteguru.com).
I did it, it helps but it will never be perfect.
I ended up buying LS1 Edit and a WB and I really don't regret it.
__________________
98 Trans Am
MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection, Corsa catback
DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
tici is offline   Reply With Quote
Reload this Page Installed maf translator.Runs Great but ltft's are high
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
