Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2005, 04:34 PM   #1
C5X2C
CF Senior Member
C5X2C's Avatar
Default Open Loop Required
Anyone else required to run in Open Loop with these mods? I can't seem to find any thread addressing the issue through search. This has been an outstanding issue for some time. My mechanic tells me that the LGM O2 placement will not work properly with either of the OEM O2 sensors.
Upgrades include:
AFR 205 milled .024
224/228 114 LSA
LGM LT with random cats
FAST 78mm Intake
30lb Fuel Injectors
LS6 ported Oil pump
Performance Dampner
C5X2C is offline   Reply With Quote
Old 08-02-2005, 10:16 PM   #2
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
Send a message via AIM to BLOWNZO6
Why would your mechanic tell you the O2 placement would not work.
I don't have AFR heads, but have the same headers, etc. you have and my car works perfectly.
More information may help... but you will have to modify the wiring harness to get the sensors in the exhaust. I used the rear sensors and put them in the holes replacing the connectors from the fronts on them.
Both of the sensors are the same, one just has a longer wire and a different plug than the other one.
You have to use the front wiring from the car.. B1S1 and B2S1 the S2 ones only will not work.
Hope that helps you.
__________________
2008 C6Z
1964 Coupe
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
BLOWNZO6 is offline   Reply With Quote
Old 08-05-2005, 12:03 AM   #3
Bink
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '09
Bink's Avatar
Call LGM.
They will sell you an adapter to run the rear O2 sensors in place of the front sensors. This usually cures the front O2 sensor DTCs.
Then disable the rears in the PCM.
__________________
There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games. - E. Hemingway
Bink is offline   Reply With Quote
Old 08-05-2005, 02:06 AM   #4
Mr Cowl Hood
CF Senior Member
Mr Cowl Hood's Avatar
Send a message via AIM to Mr Cowl Hood
Quote:
Upgrades include:
AFR 205 milled .024
224/228 114 LSA
FAST 78mm Intake
30lb Fuel Injectors
LS6 ported Oil pump
Performance Dampner
No.
__________________
BV
Willow Springs, IL
A "V" with an LS6 is like a Z06 Sedan!
SUPPORT OUR TROOPS -- always
Mr Cowl Hood is offline   Reply With Quote
Reload this Page Open Loop Required
Tags
c4, loop, open, run
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Forum ECM-PCM Tuning Section FAQ Marcho Polo C4 Scan & Tune 141 05-18-2011 11:42 AM
How many Zs have gone KABOOM with 500 to 550rwhp with Procharger set-up? Mopar Jimmy C5 Z06 Discussion 16 08-05-2005 12:26 AM
It wont run!! 65coop C4 Tech/Performance 76 04-05-2005 04:52 PM
Open Loop Required after H/C Upgrade C5X2C C5 Scan & Tune 14 03-20-2005 09:19 AM
LS-1 with sidepipes??? SteveG75 C3 Tech/Performance 22 10-14-2004 02:11 AM
What are the benfets of upgrading and LT4 to an LT4 hot cam, Exactly Gonzo C4 Tech/Performance 34 12-15-2002 10:27 PM
Thermostat results kkonen C4 Tech/Performance 35 06-21-2002 11:41 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
