I've had P0171 & P0174 codes (lean condition bank 1&2) come up 3 times in the last 500 miles, usually after hard runs. The only mods on the car is a Halltech Stinger intake that has been on for 5000 miles. I also noticed a little surging during 2-4 k rpms when cold and not as noticable when warm. Any idea whats going on? Is it really running lean?
I found one of the clamps at the tb very loose and I tightened it thinking that was the problem, however the next time I took the vette out it threw the codes again after jumping on it. Does it have to relearn after getting more air via the leak?
I would say you are sucking air somewhere check all your clamps on your intake make sure the collar going to the throttle body is on flush all around. I have seen this happen before if its not flush all around you will suck air and throw codes. Just my2 cents
All air leaks are fixed and no codes. The air duct was leaking at the maf and the throttle body. Everything was nice and tight when I installed it a year ago but i guess constant changes in temps and vibration caused it to work loose.Thanks for your help.
