Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-30-2005, 04:15 AM   #1
Racetronix
Premium Supporting Vendor
Racetronix's Avatar
Default LS1 to LS2 Conversion Harnesses
Please see our new cam sensor adapter harness
and our knock sensor relocation harness
Thank you.
Racetronix is offline   Reply With Quote
Old 08-03-2005, 11:14 AM   #2
Racetronix
Racetronix's Avatar
ttt
Old 08-04-2005, 10:14 AM   #3
Racetronix
Racetronix's Avatar
ttt
Old 08-05-2005, 02:07 AM   #4
Mr Cowl Hood
CF Senior Member
Mr Cowl Hood's Avatar
Send a message via AIM to Mr Cowl Hood
Default Very Cool!
Thank you.
Are these the only harnesses involved in a LS1 to LS2 swap?
__________________
BV
Willow Springs, IL
A "V" with an LS6 is like a Z06 Sedan!
SUPPORT OUR TROOPS -- always
Mr Cowl Hood is offline   Reply With Quote
Old 08-05-2005, 02:22 AM   #5
Racetronix
Racetronix's Avatar
Quote:
According to our dealers these are the only two required for a block swap.
There is a new connector assembly required for the LS2 throttle body as well if you are changing it.
Old 08-06-2005, 08:13 PM   #6
TT_Vert
CF Senior Member
Send a message via AIM to TT_Vert
so teh TB will be a direct bolt in swap w/ no splicing required then??
Dave
TT_Vert is offline   Reply With Quote
Old 08-07-2005, 12:02 AM   #7
Racetronix
Racetronix's Avatar
Quote:
Dave
The harnesses we are talking about in this thread are related to changing blocks only.
The LS2 TB is a separate deal and requires a different connector be placed on the end of the LS1 TPS + TAM wiring.
Old 08-07-2005, 02:36 AM   #8
TT_Vert
CF Senior Member
so what does this mean
and what does it have to do w/ the ls2 block??
Old 08-07-2005, 10:04 AM   #9
FixedRoof
CF Senior Member
Cruise-In VI Veteran
FixedRoof's Avatar
Dave, if you want to use the LS2 90mm Throttle Body (as I did on my C5) then you must splice the 6 wires in. It's like a $30 pigtail harness. Easy as cake... simple and looks factory..
Racetronix says there is not a female connector available for an inline connection.. so you have to splice it..
__________________
99 FRC Hardtop Torch Red.
Forged 347. LG Pro-Longtubes, RPM Stage IV, Corsa Exhaust, ACT Twin Clutch...etc
FixedRoof is offline   Reply With Quote
Old 08-07-2005, 11:58 AM   #10
TT_Vert
CF Senior Member
thanks steve. I bet waytekwire.com has it. I'll have to take a look one of these days.
Dave
Old 08-07-2005, 03:48 PM   #11
Racetronix
Racetronix's Avatar
Dave
It is a special TB connector so it is unlikely Waytek would carry it.
We should have some TB connector assemblies available within apx. 1 week. We are working on a fully PnP solution but it will take some time before it is available plus it will cost considerably more.
Old 08-18-2005, 05:11 AM   #12
Racetronix
Racetronix's Avatar
TB connectors are in stock if anybody needs them.
PnP adapters will be available in a month or so.
ttt
Racetronix
sales@racetronix.com
C4 Fuel Pump Systems, C5 Fuel Pump Systems, High Impedance Injectors > 60# F/M, 57# F/M, 50# F/M, 42#, 37#, 32#, 28#, 32#, 24#
Please check our web page for low impedance flow-matched injectors from Siemens and Delphi ranging from 55-95lb/hr.
Old 08-28-2005, 11:42 AM   #13
Z06ufgrad2002
CF Senior Member
Z06ufgrad2002's Avatar
deleted post
Z06ufgrad2002 is offline   Reply With Quote
Old 09-07-2005, 05:56 PM   #14
moregrip
CF Senior Member
moregrip's Avatar
Glad to hear you have the 90mm TB working! Anyway you could help me out with the wire splicing? I'm very interested as well Sent you a couple of PM's, not sure if you got them
moregrip is offline   Reply With Quote
Old 09-07-2005, 05:57 PM   #15
moregrip
CF Senior Member
moregrip's Avatar
Any update on this? There's probably a bunch of us waiting for the PNP to come out.
Reload this Page LS1 to LS2 Conversion Harnesses
Tags
adaptor, cam, connversion, conversion, converstion, harness, install, ls1, ls1ls2, ls2, lsx, position, sensor, swap, tb
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LS1 to LS2 Conversion Harnesses Racetronix C5 Forced Induction/Nitrous 20 08-18-2005 01:53 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
