Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-29-2005, 10:40 PM   #1
Vince99FRC
CF Senior Member
Vince99FRC's Avatar
Send a message via AIM to Vince99FRC Send a message via MSN to Vince99FRC Send a message via Yahoo to Vince99FRC
Default C 1283 C code
I could not find this code anywhere. After a few minutes of driving I get Active Handling is Warming up and instead of saying complete it throws that code. I just did a clutch swap. Has anyone had this problem. Whats funny is the Traction Control light comes on and stays on, but I still can turn the traction control off and on, but that yellow light stays on. Also, as soon as it does not say warm up is complete I get service engine soon light. When I reset the process starts all over again.
Vince99FRC is offline   Reply With Quote
Old 07-30-2005, 10:18 AM   #2
Gordy M
CF Senior Member
There are two codes in the 1280 series that have to do with the steering wheel position sensor. One is for Active Handling and the other are for the cars without AH. If my memory is correct the 1283 is the AH code.
At the firewall is the SWP sensor, disconnect it an measure the voltage on the middle blue wire. It should be 2.4V, if not disconnect and turn wheel until 2.4V is registered and reconnect. If .24 or 4.9 V, you are 360deg out. This often happens after lowering and adding agressive handling alignment or other steeringwheel position changes.
Gordy M is offline   Reply With Quote
Old 07-30-2005, 05:36 PM   #3
Vince99FRC
CF Senior Member
Vince99FRC's Avatar
[quote=Gordy M]There are two codes in the 1280 series that have to do with the steering wheel position sensor. One is for Active Handling and the other are for the cars without AH. If my memory is correct the 1283 is the AH code.
At the firewall is the SWP sensor, disconnect it an measure the voltage on the middle blue wire. It should be 2.4V, if not disconnect and turn wheel until 2.4V is registered and reconnect. If .24 or 4.9 V, you are 360deg out. This often happens after lowering and adding agressive handling alignment or other steeringwheel position changes.[/QUOTE ]
When you say disconnect the SWP sensor you mean remove it from the firewall itself? Also, when you say turn the wheel you mean disconnect the steering from that joint and then turn the wheel?
Old 07-30-2005, 08:38 PM   #4
Gordy M
CF Senior Member
There is a connector at the firewall in the passenger compartment. Separate the harness. Turn the ignition on and test the voltage. If that is the problem, then raise the front end, center the steering wheel, if you have the high or low voltage, you are 360 deg out. Disconnect the steering wheel and turn until the voltage is 2.4-2.5V. If you have an intermediate reading, e.g. 2.9V, turn the wheel until it reads 2.4-2.5V, then unloosen the tie rod connectors and move them in equal increments until the correct voltage is read, then tighten
Old 07-31-2005, 05:30 AM   #5
Vince99FRC
CF Senior Member
Vince99FRC's Avatar
Gotcha.. I will check this out on Tuesday..
Old 08-01-2005, 01:41 PM   #6
suprkik
Junior Member
near the firewall? , vince doesnt have one of those anymore
suprkik is offline   Reply With Quote
Old 08-01-2005, 04:59 PM   #7
Patches
CF Senior Member
Support Corvetteforum!
Patches's Avatar
I was helping a buddy troubleshoot this code and the diagnostic procedure leads you to either the yaw-rate sensor or the lateral accelerometer. We thought it was the steering sensor also. Email me if you'd like a copy of the C1283 diagnostic.
edbon@adelphia.net
Patches is offline   Reply With Quote
Reload this Page C 1283 C code
Tags
1283, active, c1283, c5, code, corvette, handling, tcs, warming, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Code 28-tcs C1283 babala65 C5 Tech 14 08-21-2005 12:11 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
