Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-29-2005, 12:09 AM   #1
TNTC5
CF Senior Member
TNTC5's Avatar
Default LTFT bank1 & bank2 15% & 25% @ 2500-3000 rpm
I have a problem even my tuner can't even figure out. The car have a skip @ around 2500-3000 rpm, but @ full throttle the car is fine. I hooked the tech2 and it show LTFT bank1 @ 15% part throttle & LTFT bank2 @ 25%. I will list all the things that i tried to fix before i take it to my tuner: new o2 sensors, IAT sensor, MAF sensor, new set of wires, spark plugs, flow the injectors, chek for burned wires, goto different gas stations. I did all that then take it to my tuner and he tried to put another tune in my pcm still didn't change. I also have p0174 code now and then poped up. If any of the corvette forum members come accross this problem please chime in. Thanks
TNTC5 is offline   Reply With Quote
Old 07-29-2005, 02:05 AM   #2
Dixit
CF Senior Member
Send a message via ICQ to Dixit Send a message via AIM to Dixit Send a message via MSN to Dixit Send a message via Yahoo to Dixit
Can you reset the Fuel Trims on the Tech2 and see what it reads then? Or better yet, just disable LTFT and see the STFT fuel trims and see where they at.
Dixit
__________________
04 - Mercedes S600
04 - Mercedes S55 AMG
06 - Audi A6 3.2
08 - Audi A4 2.0T
Dixit is offline   Reply With Quote
Old 07-29-2005, 02:07 PM   #3
AVB
CF Senior Member
AVB's Avatar
Send a message via Yahoo to AVB
Check connections after the MAF which could be letting additional air in. Check PCV connections, manifold/egr leaks.
How does she run? Seeing any misfires?
AVB is offline   Reply With Quote
Old 07-30-2005, 12:45 AM   #4
TNTC5
CF Senior Member
TNTC5's Avatar
Thanks guys, she have alot of misfire @ part throttle, but @ wide open she run great. I have gone over and over again with vac. leaks. It there any methods of checking vac leak please help.Thanks ahead
ps. Just a few days ago i started to wash down my engine with water. I then started the car the idle raised up and sound like running on 7 cylinders and i couldn't get rid of it for a few days. You guys think that i have a vac. leak somewhere? I washed the engine after ttt.
Reload this Page LTFT bank1 & bank2 15% & 25% @ 2500-3000 rpm
Tags
15, ltft
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
