Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-28-2005, 06:29 PM   #1
JEEP/C5
CF Senior Member
JEEP/C5's Avatar
Default Should I get a 160* w/ my Predator?
I am thinking of buying the Predator tuner and noticed that many forum members and some magazines are using a lower temp stat when they make this mod. Would I be maximizing my predator with a lower stat? 160*? or 170*? Let me know what you think. (I know everybody has an opinion on which temp stat, so just predator user opinions only, thanks). I not looking to lower my temps due to over heating, just want to maximize this mod.
I have a 01 with A4, vararam, larger air bridge, corsa indy with x pipe. I don’t plan on doing any other mods, street use only. I don’t feel like its ever running hot, 192* norm, 204* in heavy traffic. I’m assuming the lower stat might make it run richer or change the timing a little bit for more performance?
Has anyone just played with the stats and noticed a power difference only? (and not the "cooler engine = more HP" theory)
JEEP/C5 is offline   Reply With Quote
Old 07-29-2005, 08:44 AM   #2
JEEP/C5
CF Senior Member
JEEP/C5's Avatar
No suggestions at all?
Old 07-29-2005, 09:43 AM   #3
tv7son
CF Senior Member
tv7son's Avatar
Jeep,
I had ran a 160 for a little over a year in my Vette. I do have the Predator also. I installed it for a pinging issue. I have fixed the pinging. And reciently put the 190 t-stat back in after a year with the 160. I think the Vette has better driveability in the lower rpm's with the 190 t-stat.
BTW the pinging was caused by extra air getting in on the backside of the MAF.
With the preditor you are able to check the error's and I found that I had 30+ errors indicating the engine temp was too cold. Whether this affected the power I don't know, I do know I get 2 MPG more on the interstate with the 190 t-stat.
I have played with the WOT Fuel Trim and Timing settings a lot, you can really slow your car down if you have something off. One time I wasn't able to get under 14.00 sec in the 1/4. I have it to 13.1 sec in the 1/4 now and will keep trying for more.
I hope this helps a little.
SFS
tv7son is offline   Reply With Quote
Old 07-29-2005, 04:25 PM   #4
JEEP/C5
CF Senior Member
JEEP/C5's Avatar
Thanks for the info, I was thinking of leaving my stat alone. Any other ideas from anyone else?
Old 07-30-2005, 12:31 AM   #5
EaglesNest
CF Senior Member
EaglesNest's Avatar
Hey, tv7son
I just purchased a preditor this week and have tweeked the stock tune a little. Can you tell me what has worked best for you? I have a
99 coupe, A4, twin cone air intake, CF air bridge and Z06 exhaust.
Thanks,
EaglesNest is offline   Reply With Quote
Old 07-30-2005, 11:23 AM   #6
tv7son
CF Senior Member
tv7son's Avatar
Quote:
Originally Posted by EaglesNest
Hey, tv7son
Thanks,
I have the default preditor tune, plus have the timing bumped up about 2%. the fans come on at 220 and 225, off at 210 and 215.
I raised the rev limit 200 rpms in 2nd and 3rd gear also.
This sounds kind of hokey but I found that there is a sound that the intake makes when everything is working at it's best. It is kind of a low rumble/snort at WOT that I don't hear when the timing or fuel trim is way off. When you are tuning by SOP you have to rely on all your senses
I know there is more for me to get but that is for another day.
Mike Mercury seems to really know about the preditor maybe he can give you some inbut.
good luck
SFS
Old 07-30-2005, 11:55 AM   #7
JEEP/C5
CF Senior Member
JEEP/C5's Avatar
So should I not worry about changing to a cooler stat? Or is it just a matter of personal preference/opinions?
Old 07-30-2005, 02:47 PM   #8
tv7son
CF Senior Member
tv7son's Avatar
Quote:
I think you can get a cooler stat and be sucessful with your tuning.
Patience is really a virtue when tuning with the predator.
But to get everything tuned to your car you need something to referance your tuning with, which I have not done.
Just using the predator you have to play around with the tuning until you feel it is right. And you know that is a is a around here as everyone has had verying sucess with their cars
Just take your time and don't get frustrated.
Now where is Mike Mercury when you need him?
SFS
Reload this Page Should I get a 160* w/ my Predator?
Tags
c5, corvette, predator, update
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
