Quote:
Originally Posted by mrr23
...if i remember correctly, you don't need to recal the PCM for a gear change as it reads tire speed not driveshaft speed.
you
must reprog after a rear axle ratio change on the A4. Has nothing to do with speedo accuracy though.
The GM tuner (GM Tech Tool 2) will only do factory available ratios. So for the A4 - it won't gear scale beyond the 3.15 ratio. The model Predator for that year has a bug in it when going past the 3.15
It can be corrected via a custom tune file available either from your Predator reseller, or Diablosport themselves.
