Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-27-2005, 02:42 AM   #1
inoyourtrippn
CF Senior Member
inoyourtrippn's Avatar
Send a message via AIM to inoyourtrippn
Default throttle body spacer (please read)
has any body tried this out on there cars? mid-america calls this a performance plate in there catalog and it installs between the the throttle body and the intake manifold . does it help, it says that it adds hp but i thought i would ask some of you first .
so please leave feed back thank you
inoyourtrippn is offline   Reply With Quote
Old 07-27-2005, 02:39 PM   #2
see5
CF Senior Member
see5's Avatar
Quote:
Originally Posted by inoyourtrippn
has any body tryed this out on there cars? mid-america calls this a performance plate and it installs between the the throttle body and the intake . does it help it say that it adds hp but i thought i would ask some of you first .
I sure is not something you hear about, let alone raves. I does not sound like something that solves a known problem.
How is that for being unbiased?
__________________
2000, 6M, Kinesis rims, VBP springs, Bilsteins, Poly bushings, CCWs -315/335 Hoosiers, (SM2), Cross-bar, G-Force harness, Sparco EVO 2 seat, forged, stroked LS7 (441CI), Halltech, Blackwing, Shaner TB, PowrMAF 100, LS3 intake, ported LS3 heads, not too much cam, Fast 50# injectors, C6 oil pan, Accusump, RPS Twin CF clutch, Kooks 1 7/8" headers, 3" catless midpipes, Z06 TIs, hardened 3.90 rear, EFILive V2, LM-2 wb, always tuning.
see5 is offline   Reply With Quote
Old 07-29-2005, 03:55 AM   #3
Skunkworks
CF Senior Member
It’s hard to say how much it helps. I picture spacer like small velocity stack. It may/should increase velocity before it dumps into plenum.
How much does it help? I would say not much. An aftermarket air-bridge will get you more and it’s dyno proven.
Mike
Skunkworks is offline   Reply With Quote
Old 07-29-2005, 04:23 AM   #4
inoyourtrippn
CF Senior Member
thanks mike i have that on order
Old 07-29-2005, 12:44 PM   #5
Tubes
CF Member
Tubes's Avatar
I have a throttle body spacer. It came with the BBK 80mm throttle body kit I ordered from Mid America. If you install a spacer, you also have to do some modifications to your power steering pump (I think that was the component...been a long time since I installed the spacer). I remember that with the spacer installed, the trottle body was bumping into one of the other accessories, so that had to be moved forward as well. All of the parts came in the BBK kit to do this. Don't know about performance gains, since I did the entire intake at one time.
Tubes is offline   Reply With Quote
Reload this Page throttle body spacer (please read)
Tags
body, c5, corvette, dyno, install, picture, spacer, throttle
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
