Quote:
Originally Posted by Mike Mercury
The 1999 thru 2003 exclusive model of the Predator has a gear scaling "bug" for the C5 A4. So it doesn't matter what you set it to... it's not going to make any difference.... at least as I've always understood it to be.
Possibly one of the other settings you changed gave the SOTP improverment ???
Mike, thanks for the information on the bug. I was wondering why it was reflecting the wrong gear ratio.
I added 5% power enrichment, advanced the spark 10% (2 degrees?), raised the shift RPMs to 6000 across the board, raised the rev limiter to 6200, added 5% shift pressure, and -5% on the shift time. I assume that those changes are what probably gave it a kick in the pants if the gear ratio isn't part of the equation.
