Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Parts for Sale/Wanted
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Corvette Performance Parts, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements, OEM, Aftermarket Sponsored by
Mid America Motorworks
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-25-2008, 01:02 AM   #1
grunge09
Junior Member
Default GM Chevy Aluminum 18 Degree Heads Engine Roller Rockers Motor Block Rods Pistons Cams
I bought out the contents of a storage unit and the below items were in it. I am not a mechanic I can only describe the items as best I can. There are lots of pictures of everything.
Asking price for it all is $4000.00 or best offer.
I believe I have most all the big pricey components for a stout Chevy/GM Race/Performance Motor. Items are ALL USED and as follows...
GM (18 degree ??) v8 Engine Block 363236 CONV F3 BO (or 80) and Spec 286. Oil pan is dry sump, there is a dry sump block/module also included.
Aluminum Heads Cast #'s are 10134363 (according to my research it may be 18 degree heads). Also has 1095 (above that is 364) stamped in the top of it.
On the outside side of the head it has JGR 203, and 04278 under that, (JGR maybe Joe Gibbs Racing perhaps maybe not). Comes with all valves, Jesel (ARP ? ) roller rocker stands, valve springs rockers, springs are in a separate boxes. Also is a set of what looks like custom aluminum valve covers (could not find a name)
On the other head it is stamped 4 98 (above that is 364) and 355. On the outside side it is stamped TA011 and 04639.
Roller Rockers say CABL 165 and CUGR 165
GM Valley Plate #'s 24502652 [LC] 71M19
GM High Rise Intake #'s G1
Also have a heavy polished crankshaft. #'s on it are Express Engines 7001 #925 22 and 366+6 or 36646 (last digit may be a 9)
8 connecting rods and pistons. Pistons are JE 617FL 402797 EO-21. Could not find a name on the connecting rods. You can see maybe what they are from the pictures.
2 cams. One says RT 288-1/298R-5 5108 X0364. The other cam (one with gear on the end) #'s are 442/41495 SK 107 39 A 8359.
2 Crane Hi-6 Ignition modules (one module has wires cut too short), One with wires is Crane Hi-6R p/n 6000-6400. One with cut short wires is Hi-6DSR p/n 6000-6424.
You are getting the parts started above, there is one small box with some misc. bolts, used bearings, etc. They are included if you want them.
All parts are USED, sold with with no guarantee. Everything is pulled completely apart. some of it has red rubbery gasket material on it. Someone should check each part out completely before use. Some parts may need cleaning (valve bottoms have carbon on them as do top of pistons).
As I am not a mechanic I can not guarantee that every part is 100% working. There may be some cracks, nicks, carbon buildup, scuffs, etc. Also can not guarantee that all these parts are for this engine project. Again an engine shop should go through every piece prior to use.
I took Lots & Lots of Pictures. They are available for viewing by clicking the below link.
http://s289.photobucket.com/albums/l...ngine%20Parts/
grunge09 is offline   Reply With Quote
Reload this Page GM Chevy Aluminum 18 Degree Heads Engine Roller Rockers Motor Block Rods Pistons Cams
Tags
18, 617fl, aluminum, chevrolet, chevy, degree, engine, gibbs, gm, heads, je, joe, motors, racing, sale
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
