not sure if there is a main born on date thread
Uber Waxer
there used to be one where sponge vette would answer.
anyway, i finally remembered to write my vin down to ask for the born on date.
vin: 1G1YY32G645123651
thanks!
thanks!
St. Jude Contributor
thanks!
thanks!
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE Warranty Start Date : 04/26/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : J. B. A. CHEVROLET
7327 RITCHIE HWY
GLEN BURNIE , MD 21061-3195
(410) 766-6300
Open Recall:
#04043 LOWER CONTROL ARM WASHER 08/18/2004
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/11/2004 410391 # D1446 - DEFLECTOR, AIR (OUTLET VENT) - CENTER - REPLACE 3392 miles
10/11/2004 410391 # B3151 - SEAL, REAR RAIL (REAR ROOF RAIL WEATHERSTRIP) - LEFT - REP 3392 miles
03/05/2004 A23651 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
CONVERTIBLE
Gross Vehicle Weight Rating : 1678 kg (3700 lb) Order Number : GZMFM7
Build Date : 03/05/2004 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE EMISSIONS
F55 - MAGNETIC SELECTIVE RIDE CNTRL GU2 - REAR AXLE 2.73 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL UL0 - AM/FM CASSETTE STEREO
UV6 - HEAD UP DISPLAY UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - CD 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME: FRONT
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING 41T - T0P-BLACK
79U - PREMIUM COLOR MILLENIUM YELLOW
Uber Waxer
i see they still have the recall open for my rear washer, it was in for that, i wonder if that means those morons didnt perform the service.
MONARTOR
Uber Waxer
Originally Posted by Grumpy
or forgot to enter it..
knowing those toolboxes, they didnt perform the work....
thats ok, after gm gets my survey, they will be kissin my azz
Not sure when you had the recall done. But it usually takes 7 to 10 business day to show up that it was done. If it's been longer then that, take it to a different dealer and they would let you know if the recall was performed
sponge:
can i get build/born and options sheet on this vin number.
thanks so much!
i have to get back to you on the vin, sorry
thanks so much!
SpongeVette:
I was wondering if you'd be willing to run one more, please.....
1G1YY32G545131191
I'll be forever in your debt! Thanks so much!
1G1YY32G545131191
Originally Posted by rmherbert
Merchandising Model : 1YY07 -2001 CORVETTE COUPE Warranty Start Date : 09/09/2000
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : SHELBY MOTOR CO., INC.
PO BOX 506
SHELBYVILLE , KY 40066-0506
(502) 633-4210
CLAIM HISTORY
08/25/2000 A04910 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1672 kg (3687 lb) Order Number : CQGZZ4
Build Date : 08/25/2000 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
CF7 - REMOVABLE SUN ROOF CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE3 - SPORT SUSPENSION FE9 - 50-STATE LOW EMISSION VEHICLE
G90 - REAR AXLE-3.15 RATIO G92 - 3.15 PERFORMANCE AXLE RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL4 - ACTIVE HANDLING SYSTEM
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QG1 - PAINTED ALUMINUM WHEEL T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE 1AZ - SOLD ORDERS PROC OPTION
1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING 41U - BLACK
No service history, very nice
Originally Posted by Dale Manor
How about this one?
1G1YY32GXY5121536
1G1YY32GXY5121536
Merchandising Model : 1YY67 -2000 CORVETTE CONVERTIBLE Warranty Start Date : 03/09/2000
Delivering Dealer : YOUNG CHEVROLET, INC.
9301 E RL THORNTON FWY
DALLAS , TX 75228-6132
(214) 328-9111
Open Recall:
ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004
CLAIM HISTORY
10/31/2000 502133 # B3590 - COVER ASSEMBLY, FOLDING TOP - R&R OR REPLACE 7239 miles
10/31/2000 502133 # Z7903 - 3-DAY COURTESY TRANSPORTATION 7239 miles
10/31/2000 502133 # C7051 - COVER AND/OR PAD, FRONT SEAT BACK CUSHION - LEFT - R&R OR 7239 miles
09/29/2000 039846 # R0480 - ANTENNA ASSEMBLY, POWER (COMPLETE) - REPLACE 4384 miles
02/28/2000 521536 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1685 kg (3715 lb) Order Number : CFXG8D
Build Date : 02/28/2000 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C05 - CONVERTIBLE FOLDING ROOF
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
FE3 - SPORT SUSPENSION FE9 - FEDERAL EMISSIONS
G90 - REAR AXLE-3.15 RATIO G92 - PERFORMANCE AXLE RATIO
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
QG1 - PAINTED ALUMINUM WHEEL R9Z - POMS EXPEDITE - SOLD ORDERS
T82 - TWILIGHT SENTINEL T96 - FOG LAMPS
UL0 - AM/FM STEREO CASSETTE RADIO UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - COMPACT 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
Z51 - PERFORMANCE HANDLING PACKAGE 1SA - OPTION PACKAGE - BASE
13U - SILVER SEBRING METALLIC 41T - T0P-BLACK
70I - TORCH RED INTERIOR TRIM 703 - TORCH RED LEATHER TRIMMED SEATING SURFACE
Very nice Mr Manor
Originally Posted by blacksedan87
SpongeVette:
1G1YY32G545131191
1G1YY32G545131191
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE Warranty Start Date : 06/07/2004
Delivering Dealer : BILL HEARD CHEVROLET, INC.-SCOTTSDALE
7224 E MCDOWELL RD
SCOTTSDALE , AZ 85257-3404
(480) 947-3535
VEHICLE BUILD
Gross Vehicle Weight Rating : 1670 kg (3682 lb) Order Number : HGXQG7
Build Date : 05/26/2004 Build Plant : 145Y
OPTION CODES
GU2 - REAR AXLE 2.73 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QF5 - HIGH POLISHED ALUMINUM WHEELS R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - CD 12 DISC CHANGER, REMOTE
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
Nice choice of Color
Thanks, SpongeVette. You're so generous with your time, and I truly appreciate it!.
And yes, its a nice color choice!!
