Build Sheet Location
I just received my window sticker and build sheet (for my 01 Z06) from the NCM. I was wondering where the original build sheet could be found? I had a '67 big block vert years ago and when I learned of the tank sticker and where it was located, I checked, and there it was. Just wondering.
Actually it is supposed to be folded up and stuck inside one of the front cross members behind the bumper. It is my understanding that the sheet is near to impossible to remove intact, unless the entire front bumper assembly is removed.
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I heard that it's behind your front bumper cover, i just ordered mine from the Corvette Museum with laminent
Received 19,296 Likes
'20-'21-'22-'23-'24
If you go to the C5 Registery site, Dan has an article on why and how the build sheet is placed in the car. He even gives you instructions on how to locate it on your car.
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Thanks guys for the info. I will NOT be taking my car apart. When I sell it, I will inform the new owner as to its location.
Thanks again,
Daryl (cwmoss)
Thanks again,
Daryl (cwmoss)
Originally Posted by JDs00PewterCoupe
That's where it is.
Is this like where in the world is Waldo??
