Curb weight C5 vs C6
Old 11-11-2004, 08:37 PM
David426
David426's Avatar
Default Curb weight C5 vs C6
I've read that the 05 C6 is supposed to be lighter than the C5. the C5, from what I have read, the coupe weighs in at 3221 and the C6 at 3245. Are these the correct numbers for these cars?
Old 11-11-2004, 08:56 PM
GrayC5
GrayC5's Avatar
Curb weight: C5 coupe 3246 lbs. C6 coupe 3179lbs
2004 Corvette Specifications
2005 C6 Specifications
Old 11-11-2004, 10:36 PM
Dave68
Dave68's Avatar
...and you could get rid of most of that extra weight by swapping out two OEM things - the cat-back exhaust and the runflats. Getting rid of runflats will reduce your C5's weight by 26+lbs and installing Borla Stingers or a Z06's titanium cat-back will chop off approx. 20 lbs (guestimate) or more.
Old 11-11-2004, 10:58 PM
99C5Vert
99C5Vert's Avatar
St. Jude Donor '03-'11
Old 11-11-2004, 11:21 PM
Dope
Resident moron
Support Corvetteforum!
Dope's Avatar
Or just get a FRC/Z06 and have the lightest.
Dope
Old 11-12-2004, 12:25 AM
ExRedRacer
ExRedRacer's Avatar
Received 1,029 Likes on 549 Posts
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Or leave the wife home and save ??? pounds...
Old 11-12-2004, 12:32 AM
SilverMN6
SilverMN6's Avatar
Gee... I sure hope LiquidD1 doesn't go put all us poor folks in our places for saying we like the heavier C5(with the bigger trunk!!) when we are kidding ourselves and are secretly lusting after the C6...
Old 11-12-2004, 09:29 AM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
I checked the door sticker on my 2003 A4 Coupe this morning and the curb weight is listed as 3663 lb. That's considerablly heavier than what's in the specs.
Old 11-12-2004, 09:38 AM
Red C6 Z06
Red C6 Z06's Avatar
St. Jude Donor '05 '09
What you saw on the door was GVRW (Gross Vehicle Weight with passenger and contents). The 2004 Vert says: 3651lbs, and it also says not to exceed 399lbs in passenger and contents, so if you subtract the 399 from the 3651 (for a 2004 vert), the curb weight is 3252.
Old 11-12-2004, 09:55 AM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
OK, that's quite possible. I thought it said curb weight. I'll have to check again.
Old 11-12-2004, 10:28 AM
robvuk
robvuk's Avatar
What you're looking at is the maximum load the vehicle is capable of handling with the tires that come with the car.
Old 11-12-2004, 10:35 AM
AC54ME
AC54ME's Avatar
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Old 11-12-2004, 10:46 AM
jrose7004
jrose7004's Avatar
Received 1,675 Likes on 1,298 Posts
Old 11-12-2004, 10:51 AM
JC7
JC7's Avatar
[QUOTE=jrose7004
Old 11-12-2004, 10:54 AM
Red C6 Z06
Red C6 Z06's Avatar
You're right in that the "399lbs" comes from the tire sticker, but the GVWR is from the GM sticker and states 3651lbs. This is still the weight including all passengers and contents. I didn't look up the net capacity, but assumed that it is close to the 399 of the tire spec.
Old 11-12-2004, 01:55 PM
LiquidDI
LiquidDI's Avatar
You are all in denial!
Old 11-12-2004, 02:01 PM
jfrc
jfrc's Avatar
Dope
true
and getting rid of the runcraps saves unsprung weight- most important
Old 11-12-2004, 04:00 PM
Corvette00Car
Corvette00Car's Avatar
Two of me in the car and I exceed the allowable weight limits. Oh no.
To Curb weight C5 vs C6
Quick Reply: Curb weight C5 vs C6
