Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2004, 02:03 PM   #1
USNA62
CF Senior Member
USNA62's Avatar
Send a message via AIM to USNA62
Default Gas Door Snubbers??
Are there supposed to be a couple of rubber snubbers for the gas door? There looks to be two small holes where they would insert but my 04 has never had any. The door can be pushed in about 1/4 inch when closed. If there are is there a part number for them?
USNA62 is offline   Reply With Quote
Old 11-06-2004, 03:08 PM   #2
sweetcharity
CF Senior Member
St. Jude Donor '11-'12-'13
sweetcharity's Avatar
I do not know the part number but they should be there. Take it to the stealership where you bought it and make them get you some.
sweetcharity is offline   Reply With Quote
Old 11-06-2004, 03:22 PM   #3
talon90
Moderator
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Support Corvetteforum!
talon90's Avatar
I can't speak to the 04 but my '97 has two small rubber stops. They are not on the door, they are attached to the plastic Housing for the fill pipe that the gas cap screws onto. You can see them in this picture. The stops are on the right side just above and below the gas door release.
Click the image to open in full size.
I've checked my parts CD and up thru the '01 (which is as far as my parts list goes.) there didn't seem to be a part number. For what it's worth, even with the rubber stops I can depress my closed fuel door at least a 1/4" as well. The part number for the filler housing is 10401497 (again only sure about up to '01), it might be worth verifying that this part number is the same and infact comes with the rubber stops if you don't have them. Maybe someone has one and can provide you with the two pieces.
Paul
__________________
talon90 is offline   Reply With Quote
Old 11-06-2004, 04:51 PM   #4
RMBLROAR
CF Senior Member
RMBLROAR's Avatar
Send a message via AIM to RMBLROAR
I lost one and went to the dealer who couldn't find the part. They said it was apart of the filler tube sub-assembly and they couldn't get a part number. I ended up getting two off a salvaged panel in Carlisle.
Good luck....
Frank
RMBLROAR is offline   Reply With Quote
Old 11-06-2004, 05:44 PM   #5
RMBLROAR
CF Senior Member
RMBLROAR's Avatar
Ok... I found a part number for you. It's 10276843 and referenced in group 3 item 54. It says it's part of 10443229. Let em know if you have any lock with the dealer....
Hope this helps.....
Frank
Old 11-06-2004, 06:10 PM   #6
USNA62
CF Senior Member
USNA62's Avatar
Frank
Thanks Frank. I'll try the dealer on Monday.
Old 11-06-2004, 06:11 PM   #7
USNA62
CF Senior Member
USNA62's Avatar
Paul
Thanks Paul - that is exactly where the holes are with no snubbers. Frank provided the part number.
Old 11-06-2004, 06:52 PM   #8
Wontspeak
CF Member
Wontspeak's Avatar
Send a message via AIM to Wontspeak
Default Replace Rubber Stops
I had this done. They wrote it like this;
WARRANTY
Chk for gas cap door closing hard possible rubber stops missing.
Replaced the rubber stops due to strap missing.
B6000
QTY 2 FP NUMBER 3547884 DESCRIPTION BUMPER-F/ 12.945
Wontspeak is offline   Reply With Quote
Old 11-07-2004, 12:02 AM   #9
tdsteele
Junior Member
I had the same issue and went to the local Chevy dealer.. There are two rubber stops (called bumpers) that go into the holes you describe. Cost about $7.50 for two...but are hard to get in...you need a very pointy object like an awl... I did a good job on one but just realized when washing and drying mine todat that i lost the lower one.. When I had put them in, I kind of thought the lower one wasn't in right. I should have gone with my instinct,,,,,
tdsteele is offline   Reply With Quote
Old 11-07-2004, 01:58 AM   #10
99C5Alan
CF Senior Member
99C5Alan's Avatar
I have a package in my hands as I type this. The package has the same number as posted by Wontspeak:
The part number is 3547884 which contains a single bumper so you'll need to order two.
In 6 years of owning my car I've never lost one. Over the last year my car spent time in three shops (a long, sad story) and each time I got it back one or both were missing.
99C5Alan is offline   Reply With Quote
Old 11-07-2004, 02:19 AM   #11
3RD-INF
CF Senior Member
3RD-INF's Avatar
Go to the dealership and test drive a C-5, after you get out of sight. Stop, open the gas filler door and steal the little rubber things. Who needs parts numbers.
That's what happened to yours.
3RD-INF is offline   Reply With Quote
Old 11-07-2004, 03:48 AM   #12
14U2ENV
CF Senior Member
St. Jude Donor '04-'05-'06
14U2ENV's Avatar
Location: Lino Lakes, MN _________________________ I Figured out how to do this!
14U2ENV is offline   Reply With Quote
Old 11-07-2004, 06:16 AM   #13
talon90
Moderator
NCM Ambassador
talon90's Avatar
Frank
Wow, great find Frank. I missed that completely. Sure, it makes sense that they'd put the bumbers in a different place than the fuel housing and door
Paul
Old 11-07-2004, 02:17 PM   #14
USNA62
CF Senior Member
USNA62's Avatar
Thanks to all for your help. Great group of guys and gals on this site.
PS - here's my ride.
Old 11-07-2004, 02:59 PM   #15
Gary Wells
CF Senior Member
I have had the same issue with the rubber bumpers/stops. If you frequent a car wash, check to make sure that they are intact when you leave. Showcase Chevrolet in Westminister, Ca. ordered mine and they are in but I have not had a chance to get in and pick them up yet. The card that I got from the dealer shows part no, 10276643, which is probably a misprint and should be as shown in the post above:
102768433. Mine are being replaced under warranty. I cannot say eough good about this dealer (Showcase Chevrolet) in So Cal and I cannot say enough bad about another (Cormier Chevrolet) So Cal dealer located in Carson, Ca, right off of the 405 parking lot. See my post under either "general C5" or "Z06" on this site regarding this subject.
__________________
Thanks in Advance
Gary Wells/"TOLTK"
'02 quicksilver Z06, 55k Miles
'87 Buick turbo-Regal, 22K miles
'98 Honda CBR1100XX, 1.2K miles
Gary Wells is offline   Reply With Quote
Old 11-07-2004, 05:14 PM   #16
boatboatboat
CF Senior Member
boatboatboat's Avatar
I just checked my 04 and it also is missing these. My car had NEVER been test driven prior to me buying it, so I don't think a potential buyer stole them?
boatboatboat is offline   Reply With Quote
Old 11-07-2004, 11:13 PM   #17
xilr8n
CF Senior Member
xilr8n's Avatar
Probably some cost cutting measure.
Or maybe it weight reduction.
xilr8n is offline   Reply With Quote
Old 11-08-2004, 06:47 AM   #18
talon90
Moderator
NCM Ambassador
talon90's Avatar
Quote:
They are damn hard to get in. I found one of my bumpers loose one day (the lower one) and had a bear of a time pressing it back in until I felt like it was seated.
Paul
Old 11-08-2004, 11:37 AM   #19
99C5Alan
CF Senior Member
99C5Alan's Avatar
Paul
Wet the end with some soapy water. It should slip in relatively easy and the dried soap will act as a bit of an adhesive.
Old 11-08-2004, 12:47 PM   #20
talon90
Moderator
NCM Ambassador
talon90's Avatar
Quote:
Thanks Alan, that's good advice!
Paul
Reload this Page Gas Door Snubbers??
Tags
2004, 3547884, bumper, bumpers, c5, corvette, door, filler, fuel, gas, number, part, rubber, snubbers, stop
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
