Disable DRL - Better way than #2 Fuse?
Supporting Tuner
I searched my service manuals and I did a search of this forum before posting this thread.
There was an excellent write up by a German member on disabling the DRL. There was also the usual "pull the #2 fuse" (which works).
On Google, I found an excellent write up on disabling the DRL on the 2004 Caddilac CTS (same wiring harness as the C5??) which actually disabled JUST the DRLs and did not disable the Approach Lights by cutting one wire in the LM458 module.
So my questions are :
1> Is there a way to disable JUST the DRL without disabling the Approach Lights (which I love)???
2> Is there a LM458 module (or equivilent) on the C5 - and if yes, where the heck is it? It is NOT above the driver side footwell as in the Caddy CTS.
Any help would be appreciated.
Supporting Tuner
Anyone?
Supporting Tuner
Originally Posted by Vette Rx
What is the difference between the DRL's and the approach lights? By approach lights are you talking about fog lights?
The Approach Lights are the lights that come on when you unlock your car with the keyfob.
You can enable or disable the Approach Lights with the DIC - but the DRLs stay on no matter what unless you "take measures"
There's only 2 things I can think of that may do what you want. On my car when I release the e-brake the DRL's come on. They are not on when the e-brake is engaged. Try pulling up on the ebrake just one click (not actually engaging it). This may turn off the DRL's while driving.
Otherwise (just guessing here) can you just remove the bulbs?
Supporting Tuner
Same bulbs for turn signals and park light = nope.
What I am looking for is a permanent electrical fix to disable them without affecting any other system
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,469 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Originally Posted by OrangeVegaGT
This may sound simplistic,
but why not just remove the bulbs?
England Green,
I found this on another forum. I have no idea if a) it works or b) everything else does infact continue to operate normally. I figured I'd pass it along if you wanted to try to verify it.
From this thread Daytime Running Lights - Disable
On yet another forum I found this little tidbit which appears to have considerably more detail than the above poster. I found this in this thread, post number nine.
Running lights
Hope this helps,
Paul
All I did on my '01 Coupe was put a small/thin piece of cardboard between the relay contacts and all lights work as normal except DRLs are not on when car is.
I think it's relays 38 and 40. It's been so long, I don't remember.
Running lights
You guys are absolutely correct. Pulling that fuse will render the DRL's inoperative. However, that also has the effect of affecting the approach lights and the possibility of setting a code or two.
Here's how to disable the DRL's ONLY with no negative effect on any other system or, more precicely, without affecting the function of the approach lights.
1. In the passenger footwell, lower the front carpet.
2. Remove the foot panel.
3. Locate the IPEC (Instument Panel Electrical Center) It looks like the fuse box next to the battery.
4. Remove the cover of the IPEC.
5. Turn it over and find the diagram of the components.
6. Locate relays 38 and 40. (38 controls the right DRL and 40 the left)
7. Pull each relay and carefully remove the cover.
8. Insert some type of insulator between the relay contacts (matchbook cover cardboard or the plastic from a coffee can lid works well) that you have cut to fit.
9. Replace relay cover, replace relay, replace IPEC cover, replace the footwell.
10. DONE!!
Please remember to have the ignition OFF and if you are not comfortable doing this work with the battery connected, DISCONNECT IT FIRST.
(The procedure can also be done by installing a jumper cable in the relay socket and completely eliminating the relays, but that's a tad more involved and not really worth the effort.)
Now you have disabled DRL's and nothing more! Everything else works as designed. You haven't affected the approach lights and no other ill effect will occur.
It's a quick fix and no where near as complicated as it sounds.
Good luck.
Charlie
10. DONE!!
Good luck.
Charlie
Paul
Supporting Tuner
Thanks for all the input. It seems that Jochen's method is the only proper method to permanently disable them. I will try it and report back.
Thanks again
EG
Jochen's Method to Disable DRLs on a C5 http://forums.corvetteforum.com/showthread.php?t=776553
Thanks again
EG
Supporting Tuner
Thanks Patches!!
EG
EG
Hi everyone, I've spent hours today trying to fully disable my DRL (on my 2004 Z06) but haven't succeeded.
Steps taken so far:
Steps taken so far:
- Pulled fuse 2 | That didn't work
- Pulled relays 38 and 40 | That did not work either
- Since I didn't have images to see exactly where to insert the insulator I initially covered both sides of the contact | Result: the DRL remained on and the signals on the rear started to blink much faster).
- Then I covered the bottom part only of the contact | Result: the DRL remained on and the signals on the rear started to blink much faster).
- Then I covered the top of the contact | Result: DRL remained ON when I have my headlights on, but DRL remains OFF if I have the headlights OFF, the rear signals on the rear worked normally).
I knew it. I was going to ask if this was a USA market car or export.
I answered in another thread where to find fuse 2 in your fire box.
I'm sorry I can't help you with an answer about the export DRLs.
I would suggest starting a new thread about export DRL disabling instead of bumping old threads.
EdgySloth (12-03-2021)
This is a US spec car. I imported it from Texas in April, so any feedback from American brothers will help me keep Corvettes running in Europe.
Either this did not work for an 04 or I'm going to guess that the importer modified your lighting to comply with your country's laws before you got your hands on the car.
Hi everyone, I'm in Ireland and I'm only doing this because it's a legal requirement to disable DRLs to pass the required inspection, as well as many other things (e.g. install orange side reflectors, euro spec tail lights with orange indicators, etc.). DRLs never bothered me and wouldn't even think about modifying them, but I have to disable them and I hope what I've achieved recently is enough to pass the inspection. Thanks
Steps taken so far:
Steps taken so far:
