Rear 18 Inch Wheels All Around
Can you do this and put a different size tire on the front to keep from tripping up the Tration Control? If so, what size tires? Anyone have any pics from the side to show what it looks like?
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
I think the back spacing is different on the rear wheels. I don't have my manual handy but I believe thet the rear wheels won't clear the front rotors.
Harold: 18s all around won't mess with Traction Control as that only effects your spinning your rear wheels. You might mean Active Handling and again, no it shouldn't effect that as it is controlled by various handling input sensors - but not wheel size.
so...I could put 18x9.5 stock wheels on the front as well with the same 275/18 tires and not trip up the Active H?
Originally Posted by MARK's_C5TT
I have that set up as a street config with no problems. 18x9.5 and 18x11
Street 18 x 10f and 18 x 11.5r with 275-35f and 335-30r
and track 18 x 10.5f and 18 x 12r with 305-30f and 335-30r
NO Problems what soo ever.
SO go for it wider tires make for better handling
Stock OEM 18 x 9.5 Mag rims all around here..........
295/35/18 out back
275/35/18 up front
Good to go!
295/35/18 out back
275/35/18 up front
Good to go!
295/35/18 out back
275/35/18 up front
Good to go!
295/35/18 out back
275/35/18 up front
Good to go!
Night Owl for life
Received 3,241 Likes
I moved stock rear Y2K's to the front and bought a set of 18x10.5's for the rear. I'm using 295/35 and 275/35's...I'll send you a side shot pic.
What about 18x9.5 all around with 275/40/18
Tom:
Can I have your race wheels?
If that's asking too much....then can I have your car????
Any pics you could email me of the side view...Ill bet the Mags look great in all 18
Yeh it was a 4 x 4 with these but it was just an experiment, road good though. Good luck
Here is the best side shot from yesterdays show
275/35/18 front & 295/35/18 rear
Yokohama AVS sport non-runflats.....Wife's EDD!
Originally Posted by CAJUNY2KC5
Tom:
Cajun your sounding like my girlfriend. She wants my street wheels
before or after I put the cage in and T1 suppension on??
Does any vendor make a Polished/clearcoated wheel like the stock in a 18x9.5 and 18x10.5? The chrome is too bright for my taste. I prefer the stock look.
