Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-15-2004, 03:49 PM   #1
dsharkman
CF Senior Member
Default c5 squeaky convertible top
I own a '98 convertible. When the top is down, I can hear squeaks from under the top compartment on the driver's side. Since this is an intermittant problem, Chevy has been unsuccessful in troubleshooting. The squeaks only originate in the top down position. Has anyone experienced this problem? How did you fix it?
Thanks.
dsharkman is offline   Reply With Quote
Old 09-15-2004, 06:58 PM   #2
Tally Ho
CF Senior Member
Support Corvetteforum!
Tally Ho's Avatar
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Mine squeaks on the passenger side. I just turn the stereo up.
__________________
2006 conv 3LT,Z51,MX0,LMB/black/ebony (30Jan06)
Mods:LG Pro long tubes, Borla Stingers, A&A V2 Si, Caravaggio rear widebody, LG World Challenge wheels, GM full width spoiler
Former Vettes:
1982 Collector Edition (1985-1992)
1989 Convertible-white/blk/blk(1990-2002)
1998 Convertible-black/blk/blk(2001-2005)
1982 black/silver grey (2010-2011)
2013 427 conv. CRM/blk/blk (2012-2014)
[IMG][/IMG]
Tally Ho is offline   Reply With Quote
Old 09-15-2004, 07:06 PM   #3
BobH
CF Senior Member
BobH's Avatar
I don't have a vert but don't you think the squeaks would come from the metal sub-frame rubbing on itself? Perhaps you can (if you haven't already) lube the contact points on the frame and see if that fixes it?
BobH is offline   Reply With Quote
Old 09-15-2004, 07:32 PM   #4
cl601amt
CF Senior Member
cl601amt's Avatar
Send a message via AIM to cl601amt
My 99 Vert was rubbing on the cover, I now carry a rag to place over the latch when it is stowed
cl601amt is offline   Reply With Quote
Old 09-15-2004, 09:58 PM   #5
88sk
CF Senior Member
88sk's Avatar
checkout the backbone mod ,maybe that'll work.
88sk is offline   Reply With Quote
Old 09-16-2004, 09:03 AM   #6
Fast one
CF Senior Member
Mine did that. There are rubber pads on the inside of the rear hatch that are supposed to push down on the top so it can't move up and down which cause squeeks. By adding foam rubber to both pads the top can't move and the squeeks should stop. While driving with the top down reach around and hold the top down to see if this is what is happening in your car.
Fast one is offline   Reply With Quote
Old 09-16-2004, 11:07 AM   #7
Rob4092xx
CF Senior Member
Rob4092xx's Avatar
Try this....anywhere you have "rubbing" going on, put a light coat of WD40 on it.
To apply, spray WD40 on a paper towel and then wipe the area down slightly.
This will eliminate any friction between the surfaces which causes the squeeking noise.
This works well on any surface, i.e.: metal to rubber, rubber to rubber, metal to metal, etc.).
Rob4092xx is offline   Reply With Quote
Reload this Page c5 squeaky convertible top
Tags
2005, c5, convertible, corvette, sqeaking, squeak, squeaks, squeaky, squeek, top, tops
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 03:33 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
