Eradix Pro Brake Upgrade System
Old 09-10-2004, 05:28 PM
TKO Performance
Premium Supporting Vendor
TKO Performance's Avatar
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Default Eradix Pro Brake Upgrade System
Dear Corvette Forum members,
I wanted to present the ERADIX Pro which is an excellent new brake upgrade for your 97-04 by Brake Pro’s.
The ERADIX Brake systems have been designed to offer greater brake performance over standard size Cross-drilled and/or Slotted brake discs.
The two-piece front & rear Cross-drilled / Slotted discs offer improved braking performance by reducing weight through the use of billet aluminum mounting bells. This two-piece system also reduces heat transfer into the bell area reducing the chance of warpage. The disc’s vanes are directionally curved to pump air and pull heat away from the friction walls dissipating heat more rapidly. ERADIX PRO systems are a perfect upgrade for the performance enthusiasts. These kits come pre assembled and do not require bleeding the hydraulic system
PRO Features:
— OEM Size one and two-piece Discs – For improved braking.
— Two-piece Discs have billet aluminum mounting bell - For reduced weight.
— Two-piece Rear Discs have steel hats –To reduce warpage and to
accommodate the emergency brake.
— Cross-drilled & Slotted Friction Surfaces - For Improved Pad Bite.
— Curved Vane Disc design - For maximum cooling.
— Thermal stabilization heat treat - To eliminate warping.
— Maintains factory Disc offset & wheel track.
Front retail for $708
Introductory price $678
Rear retail for $592
Introductory price $562
Offer ends 9/25
Feel free to contact us to place your order or ask any questions you might have.
Thanks Cory
__________________
Serving The Corvette Forum For 21 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
Old 09-13-2004, 09:28 AM
TKO Performance
ttt
Old 09-16-2004, 11:08 AM
TKO Performance
To Eradix Pro Brake Upgrade System
Quick Reply: Eradix Pro Brake Upgrade System
