Oil life reset
Old 09-10-2004, 05:43 PM
One Blue Vette
One Blue Vette's Avatar
Default Oil life reset
How do reset the oil life gauge and is that based strictly on milage?
I tried to hit the reset, but it wont reset to 100%
Old 09-10-2004, 05:47 PM
slicksilver11
slicksilver11's Avatar
having the same problem. did the book procedure and also the trick with the gas pedal.
Old 09-10-2004, 05:49 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
To answer your first question, it's not calculated on miles driven, but rather number of engine revolutions (RPM), oil temp., etc.
An easy way to reset the oil monitor is turn the ign key "on" but don't start the car, and fully depress the gas pedal 3 times in a row, one right after the other.
I believe the monitor will never display more than 99%.
One Blue Vette
What is the book procedure? is it just to hit the reset?
Old 09-10-2004, 05:56 PM
One Blue Vette
Thanks Dan. I will try that on they way home from work today.
Old 09-10-2004, 06:08 PM
Richin Chicago
Richin Chicago's Avatar
It will display 100% right at the point of reset.
Old 09-11-2004, 12:07 AM
Dan_the_C5_Man
Hmm. O.K. But it seems like the last time I changed the oil, it went straight to 99%. Keep in mind I didn't use the gas pedal method; I reset it from the switch panel. But I would think the logic would be identical. I'll try and remember what it does next time. I'm also wondering if it could vary between the older (pre 2001) vs newer (post 2001) model years.
Old 09-11-2004, 02:15 AM
GrayC5
GrayC5's Avatar
How to Reset the "Oil Life" indicator
After an oil change, you need to reset the oil life indicator so that you know when the next change is due. Here is how to do that:
1) Turn the ignition on, but make sure the engine is off.
2) Press the "Trip" button on the DIC so that it displays "OIL LIFE" percentage.
3) Press and hold the "Reset" button for two seconds. "OIL LIFE REMAIN 100%" should appear on the display.
Old 09-11-2004, 11:25 AM
drosenth
drosenth's Avatar
I had the same problem - the reset button didn't allow it to go back to 100%. I used the "pump the pedal three times" and it worked like a champ. Not sure why, but the reset feature only blanked my out, but didn't put it to 100%.
HTH,
DaveR
Old 09-11-2004, 11:28 AM
NoelsTorchredZ
NoelsTorchredZ's Avatar
Either method will work and I always get 100% as soon as I'm done. Mabye that extra 1% means I'm special
To Oil life reset
Quick Reply: Oil life reset
